Well, I brought this issue up to Kevin with a previous playfield purchase. I've attached my comments and his responses below. I talked to the guy who does my playfield work now about this and he did affirm that this is not unique to CPR. He couldn't say Kevin was wrong is his analysis, but he did have a different theory. His take is that when you have crystal clear inserts (clear meaning not frosted/light diffusing), they get crackling/crazing when they get pressed into the playfield and it is very noticeable. The recent clear coats are really clear and shiny which makes the cracks much more apparent. He showed me examples of some original B/W playfields (DMD era) and the same kinds of issues are there but to a much lesser extent. But, we also talked about ways that the playfield could be screened and cleared that would prevent it from being noticeable.
I am disappointed in CPR for not taking this issue and trying to improve on it. There ARE solutions but their attitude is to simply say that's the way it is. CPR recently had offered playfields without clear and took advantage of that recently. On those 2 playfields, I had my guy clear them and I see NO crackling/crazing on a single one of those inserts. They're gorgeous top to bottom. So, I'm not convinced that there is a "just have to live with it" scenario. If CPR had offered that on the Whirlwind playfield, I would have gone with it.
For the record, my Whirlwind playfield that I just received from CPR is full of crackled/crazed inserts (as noted and photographed in this thread by others) and there is nothing much you can do about it since it's already got a coat of clear on it.
I'm not trying to bash CPR here. I'm just trying to make the point that the issue noted here is not unique to the Whirlwind run. But, I am disappointed in CPR for not making a concerted effort to improve things.
Jaz
Jaz said: "The playfield looks pretty good. I'm a little disappointed in that a number
of inserts show some crazing. Did some of those inserts come from old stock you had in stock? I'm hoping that the crazing won't show once installed and illuminated. I've only had a few minutes to look at them, but it's possible that the crazing is between the insert and the clear. Have you heard of this before? Is there a chance it will clear up in time?"
Kevin said: "I'd have to see what you mean by crazing. Yes, the inserts are from 2005. But
that shouldn't make them any different than inserts molded fresh. Clearcoat
reveals in pure clarity whatever the body of the insert looks like, and all of
them are different. Clear doesn't "do" anything to an insert, but it does make
it look permanently wet as with the whole surface. So whatever was in the
insert when it was molded (crystals, bubbles, ripples, pressure fracture lines,
etc) will all be there forever. Inserts are like that in every one of our
playfields - especially if they are transparent. And clearcoat is not forgiving
in hiding the details of inserts. It reveals all."
Jaz said: "What do you think is going on with these inserts?" (pics attached)
Kevin said: "Those are molding crackles from when the insert was molded and cooled.
They are found in probably 1 in every 10 inserts, if they are
transparent style plastic. I explained it a little bit in the prev
email you had attached. Just so you can see it's common in all our runs,
here are some examples from the old Fathom photo gallery from our site
(photos attached).... the image on the left in each frame is the 2004
Fathom run, the right is 2009 Fathom re-run."
Post edited by Jazman : typos
