So it was time to start tackling the upper playfield job I’ve been dreading forever.... the installation of the wire guides.
I thought I would start in a fairly hidden spot first, behind the 4 bank. I’ve never done this before & I was concerned I’d crack the clearcoat, or even worse, lose control of my dremmel. Here’s what I did...
1) My playfield was recleared by Kruzman. So these holes needed to be prepped first. The wire was 3/32 thickness, but the drilled holes were only 5/64. So they would need to be enlarged before hammering.
2) I took the 5/64 bit in my drill & deepened the hole. I took my point dremel bit again, then ran it VERY slowly at 1 speed so it wouldn’t bind up. I carefully inserted in the hole, grinding away the clear at the edge of the hole, making it a bit wider.
3) The hole is still too small, so now I switched to the 3/32 bit, and then made it bigger. Be sure to drill deep enough to pound the guide in. Then hit it again with the pointy dremel to grind away the clear. You can see the final enlarged hole on the left, then original hole on the right.
4) I used my wire bending rig to adjust the guides & get them just how I wanted them.
5) Using my dead blow hammer & small piece of wood, I tapped them in. They went in snugly & firmly. I used a ball to check the height, right at the middle of the ball.
