So with a deep breath & a steady hand, I proceeded to begin countersinking holes for the t-nuts with the 1/2 inch forstner bit.
Placing a depth stop on the bit was not possible, so I just had to be careful. The goal was to drill down 1/8 inch into the playfield. Luckily this PF wood was pretty dense & hard. I just went in in short bursts.
After that was done, I had to widen the hole with a 3/16 bit, to allow space for the shaft of the t-nut. I ran the drill in reverse & used a depth stop to ensure I didn’t drill too far down.
Success! Glad that part is over. But I’m glad I did it. The original single bolt method Stern did at the factory was a cost saving measure, and it's just not adequate strength. When I pulled these bolts from the Meteor, alot of them were bent, due to repeat bashing. Eventually the holes in the playfield may widen & then the post is loose with no way to secure it. There were only 2 posts holes where I didn't have space to place a t-nut, by the standup targets near the pops.
With the t-nuts installed these posts will be rock solid, using a standard 2” post screw, and the correct 1-1/4” posts.
I should add I did the drilling with the PF on a hard flat surface, not in the rotisserie.
23FDD7E4-32AE-4A80-849E-AF85C12A7CCA (resized).jpeg148D11CF-6AC5-4483-9C73-8CA605FD0D02 (resized).jpeg00828C85-BA97-4B4B-A7CA-13970659CC10 (resized).jpeg622F6EC6-FC9D-490D-B784-67B9CCE90637 (resized).jpeg
