(Topic ID: 234899)
My 1st GTB system1 - HELLLLPPPPP! :)
By DropTarget
5 years ago
  • 56 posts
  • 10 Pinsiders participating
  • Latest reply 5 years ago by DropTarget
There are 56 posts in this topic. You are on page 1 of 2.
#1 5 years ago
Hi,
I just picked up a Count Down. It's my first experience with a System 1 game.
I've come across some issues and am hoping to get advice/input from the group.
1) When I first got the game, the displays worked. I "tinkered" with some connectors on the CPU and now they no longer light.
2) I've been checking voltages, The Bridge rectifiers are good, the power supply is putting out +5VDC and -12VDC on J2. I'm getting 4VDC and 8VDC on J3 7,8.
But am not getting either 42VDC or 60VDC on J3 1 or 3.
3) I'm guessing that the attached picture is not a good sign for the CPU (corrosion?)
so.....HELLLLPPPPP!!!!!
thx
#2 5 years ago
Order some parts and start repinning connectors.
Remove that battery and neutralize the acid.
The 42V and 60V have their own special ground, are you measuring from that?
The displays aren't working. Is the game still booting? On my Count Down, sometimes it wouldn't boot (or won't boot properly) until you reseated the connectors on the right.
Consider just buying a replacement MPU or LISY1 if you continue to have trouble. The original system 1 MPUs aren't really worth bothering with that much in my opinion.
#3 5 years ago
Thanks,
As per Clay's youtube video, I'm taking ground from the 200mf cap that's just below the male connector. I'll double check, maybe the 1/4a fuse is blown, but it checked good before.
I'm hoping that I didn't blow the little transformer when I was jiggling connectors with the power on. I didn't see, hear or smell anything.
I'm considering a new CPU. perhaps the all in 1 board.
I'm going to be locked in a hotel room for a few days, maybe I can bring the harnesses with me and start repinning.
#4 5 years ago
Quoted from DropTarget:
Is this because your wife is angry you brought home another machine? A not working machine! Just giving you a hard time.
Enjoy the challenge of the new machine!
#5 5 years ago
no comment!
but on a serious note....do you know what size pins to use? .100 or .156?
#6 5 years ago
That Data Sentry is the original battery; I can see lots of corrosion damage just from the picture, not good.
I'd say check out the Janin all in on board: https://www.flippp.fr/boards.php?lg=en; this will eliminate the lower connector to the driver board that must have damage from the corrosion.
#7 5 years ago
Thanks, That's where I was leaning
#8 5 years ago
I'm a Bally guy. The .100s are the smaller ones used on the MPU and the .156 are on the power supply and larger size on solenoid driver board.
I'm sure someone else can provide more detail for this Sys 1 game.
My wife said no to pin #2 and then said no to pin #3. Guess who was playing them tonight with me! I don't think there will be a 4th. We ran out of space on the wall in the basement. Maybe time to remodel...to fit more pins.
#9 5 years ago
lol,
When I first moved into my house, I told my wife that I wanted a pinball machine. She said "OK, you can have one (1)" I'm up to 20 or so now.
She ignores it all.
#10 5 years ago
I recently rebuilt a Count-Down machine. Found lots of broken/cold solder joints on the original power supply. Fixed those and installed some caps that were dried up and out of spec. Also did the ground mods on that, the driver, and the MPU board.
You'll definitely need to clean the edge card contacts and re-pin some of the connectors on the cable. I'd relocate the battery off the board and clean up all the corrosion. The original board may be revived as long as the spider chips are ok.
#11 5 years ago
Thanks. I was just about to hit the purchase button for the all in one board, but damn, it's expensive.
How would you clean up the corrosion? Vinegar?
#12 5 years ago
I'm still trying to figure out why the displays stopped working
#13 5 years ago
I would suggest reviewing the Wiki on the System 1 games to start with:
http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_1
And this site:
http://www.pinrepair.com/sys1/
and also this one:
https://www.flippers.com/servicing_the_gottlieb_system_1_.html
Check/verify all your voltages and check the connections. That can clear up a lot right there. Do not plug and unplug those displays when it is one. I've heard that can cause issues.
#14 5 years ago
I'm going to update my checklist tomorrow. There is an easier way to measure voltages on the power supply. In a nutshell. The 5, -12, 4, and 8 volt use the ground in the top connector. The 69 and 40 use the ground on the right connector
#15 5 years ago
Thanks,
Maybe It's a bad ground? Should I be taking ground from the ground pin on the right connector instead of the capacitor lead?
#16 5 years ago
I checked incoming voltage across pins 6 & 7 and got 79V
BTW, I'm an EM guy, not that much experience with SS, yet alone a System 1.
The thing that perplexing me about the displays is that they did work. I noticed that now, after the game had been off for a while, I turned it on and the #3 player display lit dimly for about a second before going out. Also, the heaters seem to work, I connected them to an external 6VDC source, and they glowed.
#17 5 years ago
OK,
After going back and forth on what to do, order an all in one board, which seems the easiest but most expensive way to go, or order a new power supply and CPU, which is less expensive, but might not repair all issues, or repair the power supply and cpu myself, which is time consuming and may not work in the long run, I've decided to 1st repin the connectors and then recheck voltages and go from there. I suspect that I'll need a CPU as A1-J6 just slides right off of the CPU, nothing left for it to grip and I haven't had great luck when trying to clean up CPUs in the past.
Stay tuned....This may take a while!
#18 5 years ago
Thanks,
Not a bad ground per se but the split ground on the sys 1 power supply is confusing. The displays have worked. You've seen them. You have power. It's likely connectors at this point.
The top and bottom connector on the power supply, the power connector and all the bottom connectors on the mpu are suspect.
I have never had to redo a display connector on a system 1. Either at the mpu or the display.
#19 5 years ago
Before you do, you can always try giving the repair attempt a fair shot. You may get it going again, would be good practice, and if you butcher anything too much, you always have a backup plan.
However, I must say, that Pascal All-in-one board is worth every single penny. Everything is socketed, and the board has some really nice circuit protections and redundancies, and minimizes connector failures; plus it adds nice features like a modern attract mode and updated rules (that can be turned off if you're a purist).
Still, if you decided to go that route, you still need to repin all the connectors at a minimum.
#20 5 years ago
Thanks,
I that's going to be my plan of action. right now, 'm trying to desolder the old battery. What a PITA!
#21 5 years ago
Thanks,
If you can reach the legs top side just cut if off
#22 5 years ago
I simplified the instructions for testing the power supply in the checklist
#23 5 years ago
Quoted from Cheddar:
Couldn't get to the legs. I had to cut the top of the plastic housing off and remove the batteries. Then I was able to grab the legs with some pliers and desolder them.
#24 5 years ago
Thank you. Is it the same link?
#26 5 years ago
Great!
I'm going away for a few days and won't be able to get back to the game for a little while. Boy I hate being away when I want to keep working on the machine.
Oh well, work calls.
to recap (no pun intended), here's where I'm at.
1) Game used to light displays, although no 5 second delay. Player 2 display was dim.
I jiggled some connectors on the CPU while power was on, I didn't play with the display connectors though. Then lost power to the displays.
2) Started running Clay's procedures, using your Spreadsheet.
The fuses are good, Bridge Rectifiers show proper resistance.
3) The 5V and 12V outputs to the CPU from the power supply are there and within tolerance.
4) No High Voltage output to the displays even though the input across pins 6 & 7 to the power supply is 74V.
5) The 4 and 8 volt output to the displays are there and correct.
6) I removed the CPU, desoldered the battery.
Here are pics of the CPU. Do you see ay reason to scrap the repair and buy a replacement?
Any thoughts one why no high voltage to the displays?
My plans are to start re-pinning connectors when I get back home. I'm keeping my fingers crossed that that will restore the high voltage, but am not optimistic at this point.
Thank for all of the help so far.
-W
IMG_5321 (resized).JPGIMG_5321 (resized).JPGIMG_9691 (resized).JPGIMG_9691 (resized).JPG
#27 5 years ago
So the only things affected that is not a resistor or small cap (cheap) is Z8 SN7404N $3-5 and Z28 DM7405N $1-5
If this was my board I'd take a shot at it.
Here's the pinwiki on this damage: http://www.pinwiki.com/wiki/index.php?title=Gottlieb_System_1#Battery_Leakage_and_Corrosion
#28 5 years ago
Thanks, I was concerned about some of those chips.
#29 5 years ago
I think what you have if fixable, but I am concerned about a couple things.
You say the displays used to come on, but instantly with the power? This suggests to me that the Slam Tilt is open.
On the CPU, as long as the spider chips are still good, then the board is repairable. If that board were mine, I would use thick, acid-based toilet bowl cleaner on the corroded areas, then scrub those areas with a brass wire brush
1acidtoiletbowlcleaner (resized).jpg1acidtoiletbowlcleaner (resized).jpg1wirebrush (resized).jpg1wirebrush (resized).jpg
#30 5 years ago
Warning: never use acidic bowl cleaner in a stainless steel sink
#31 5 years ago
Next thing I would do is repin the connector housings that's under that battery-damage zone.
Watch videos on using this tool. They are easy to break
#32 5 years ago
Quoted from songofsixpence:
Docent has the Economy pin remover @$2.50 https://www.docentelectronics.com/httpdocs/AmusementGames/Pinball/Gottlieb/System%20One.htm
#33 5 years ago
Those card edge connector housing use Molex 08-50-0106
7 cents each, when you buy 100 through Mouser.
#34 5 years ago
for the card edge fingers, it is recommended to clean these with a pencil eraser. You should not use anything abrasive, except as a last resort.
My new favorite thing to clean card-edge connectors is a Brightboy. They were designed to clean model railroad tracks, and do a phenomenal job with edge connectors. They also work well on IC-chip legs.
#35 5 years ago
GPE can supply all you need without having to order from two suppliers, Ed is one the best guys in the business and will take care of you. Great Plains Electronics
#36 5 years ago
If you would like further advice, I'd be happy to drop by one day for a visit.
#37 5 years ago
Is that made by Micro engineering co.? Curious to try one as I too use a big pink eraser. Is the site under same name?
#39 5 years ago
Thx songofsixpence I'm going to order one and give it a go!
#40 5 years ago
Yes, both the door slam switch and the tilt switches are/were open.
Now you tell me!
Thanks, There's an old timey electronics store not too far from where I live. I'm sure they have the tool. I know they have .156 connectors. I already have a bunch from a previous project.
Quoted from RWH:
Yup great guy. I may pick up new edge connectors from him.
Cool. I've used pencil erasers on Seeburg Jukebox formats. I'm wondering if that "we buy Lionel Trains" place on rt.46 in Parsippany would have them.
That would be great, I'm away from home right now. I'll be back in a few days. You're always welcome to come over, worse comes to worse, if we don't get this game going, we can play some pinball, hell we can do that either way.
#41 5 years ago
Do you think this would substitute for a DM7405N as they are out of production. Mouser and Newark Electronics recommend them instead. I can always get a DM7405N on eBay if needed, but I for 1.91 I ordered the recommended replacement from Mouser.
https://www.mouser.com/ProductDetail/595-SN7405N
#42 5 years ago
you want this:
https://www.mouser.com/ProductDetail/Texas-Instruments/SN74LS04N?qs=sGAEpiMZZMutVWjHE%2fYQw%252bapLJeN9MxpLZ2LWnfirGs%3d
I have some you can have. Plus Wayne Electronics likely carries them. That's the old timey electronics store you're referring to, right?
Don't forget the sockets:
https://www.mouser.com/ProductDetail/TE-Connectivity/1-2199298-3?qs=%2fha2pyFaduiJXpyNSCmeIGM6DzzoVc4nhSZHzOok1pM2dZZPNM9TKQ%3d%3d
#43 5 years ago
oops, Mouser recommended the other chip, so I ordered one. If you have an extra, I'd gladly use that.
Yup, Wayne Electronics. I called them today re: the pins, but he only had 10 pieces.
Guess what I forgot!. I saw the chips were soldered to the board, so didn't think of sockets. Maybe Wayne Electronics has them.
#44 5 years ago
I can't believe the Molex brand tool is $22.00
I found that a probe from my multimeter works perfectly.
#45 5 years ago
here's a thread...
https://pinside.com/pinball/forum/topic/stripping-battery-corrosion-with-a-strong-acid
#46 5 years ago
#47 5 years ago
Great news. What did you do to get it to work?
#48 5 years ago
Well, It's not exactly working, But the displays power up.
I cleaned and neutralized the CPU. I re-pinned A2J1.
I was still not getting high voltage, and now the +5V output was intermittent. Then I noticed that pin 7 on the input header was pushed in about an 1/8th of an inch. I pulled it out, and voilÀ.
I had given up and ordered a new Power supply, then figured this out about 5 10 minutes later. I went to cancel the new power supply, but tit had already shipped. I'm trying to decide to put in the replacement or keep the game original. I guess I'll keep it original if the CPU is good. If I have to replace it, I may as well replay both.
I won't get around to re-pinning the other connectors until sometime next week.
Stay tuned, and thanks for the support/help.
-W
#49 5 years ago
I was still not getting high voltage, and now the +5V output was intermittent. Then I noticed that pin 7 on the input header was pushed in about an 1/8th of an inch. I pulled it out, and voilÀ./help.
-W
The header pins on the bottom of the power supply? Good indicator of cracked solder joints
#50 5 years ago
Yeah you'd better reflow those pins, 7 shouldn't have pushed in or out.
$ 7.50
$ 5.95
The Pinball Scientist
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/my-1st-gtb-system1-hellllppppp- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
