It's a lost cause so you need to give it to me.
If it's coming on and off at pretty much random times, I'd check the connection and the bulb. The Stern sockets aren't the greatest so it could be a case of the bulb just being lose in there. If that's not it, maybe swap bulbs to see if the problem moves to the new location, if so, it's the bulb.
If that all fails, then I'd look for a pinch in the wire somewhere between it and the board as there may be a small break in the wire (but not through the insulation) that is causing it to be flaky.
