I used to use horses, now I have a harbor freight lift table.
Quoted from Shredso:If it had a Pinball Life logo on it and was covered in black tolex and was $50 would it be better?
No, but if it had a bunch of crappy action figures glued to it you might just peak my interest sir
I use my knee, but this looks ok enough, I think I'd add a couple of diagonal supports though at the join, and use it with the T part on the floor to spread the load on the underside of the pin.
Quoted from BoJo:2x4's can handle over 600 lbs vertically, so I am sure he is fine.
Yea, I don't see weight as being an issue. My only concern would be side to side movement...if the machine got bumped, the verticle piece might want to lean over. Screws don't grip as well in the end grain as well as they do across the grain...they may pull out. Maybe add short gusset on either side of the joint for stability?
My 2 cents...
Quoted from Shredso:Just because it's cheap doesn't mean it doesn't work. If it had a Pinball Life logo on it and was covered in black tolex and was $50 would it be better?
Absolutely. Pinball life is awesome!
Quoted from KenLayton:The Wico Pinball Dolly works so much better.
I drive by 6400 Gross Point Rd. in Niles all the time but can't find any pinball stuff at "the house of parts" anymore.....
Quoted from Pafasa:I like it! Not as much as I like having a pinball friend with me to help move stuff, but I bet I could staple a pic of Greg to the 2x4 and then I would have him along no matter what!!
Bwaaaaa ha ha, or just call me, I will even talk to you while you are moving all by yourself!
Quoted from Monster_Bash:All that weight isolated on 1.5 inches? Yikes...not for me....
Stability could be added just by putting a couple triangle/pieces of wood at the bottom. I use a harbor freight cart, drop it all the way to the floor. Best $150 I ever spent. Like it better than my pincart
Quoted from browne92:Yea, I don't see weight as being an issue. My only concern would be side to side movement...if the machine got bumped, the verticle piece might want to lean over. Screws don't grip as well in the end grain as well as they do across the grain...they may pull out. Maybe add short gusset on either side of the joint for stability?
My 2 cents...
That's what I'd do or double up the vertical 2X4. A single one just doesn't look stable enough. Great, simple idea and I'm sure it would work 99% of the time. The other 1% is the time someone bumps the pin on the side.
A few years ago a couple friends removed a TZ from an SUV and set it on a couple metal saw horses with the legs that fold up for storage. Weeeeeeeeeeeeell, the legs on one of the horses didn't lock correctly and the TZ came down on top of my buddy's foot, breaking numerous bones. And, of course, it didn't heal correctly after 6 weeks so he ended up having surgury.
And PL would get a "shout out" for offering such a greta(sic) product. In PL's defense, it would cost $15 or less. Not sure about Marco or Bay Area's price though...
To all the non-carpenters out there; Use wood glue and nails or wood glue and scres. It will be fine. I used to use more scres than necessary and wood joints would still distort. Dad was a carpenter and when I went to him he explained it to me. The glue provides the holding power for the weight. The nails or screws prevent a shock from a drop or blunt force from breaking the bond. If you were to screw in angle brackets or additional wood, you could still experience distortion if you only rely on metal fasteners to hold the joints.
You guys are all way overthinking this. It takes about 30 seconds to screw two legs on or off. Mr T is just an easy way to support the weight for that time if you don't have a helper. This isn't the foundation for a skyscraper. It's just there to take the weight off of your back or knees for the time it takes to remove or install four leg bolts.
Quoted from Pinballmike217:You guys are all way overthinking this. It takes about 30 seconds to screw two legs on or off. Mr T is just an easy way to support the weight for that time if you don't have a helper. This isn't the foundation for a skyscraper. It's just there to take the weight off of your back or knees for the time it takes to remove or install four leg bolts.
Amen
This page was printed from https://pinside.com/pinball/forum/topic/must-have-tool-meet-mr-t/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
