Much better - cleanliness wise.
Watching the videos again I noticed that the stepper is always stepping even though the light isn't advancing. I had overlooked that before. I also notice now that there is a set of contacts among those you circled that has no solder lug or wire soldered to it. Given those two there's another possibility.
Since there are 7 lights the stepper has to take 7 steps to sweep through all of them. I think this stepper only advances and doesn't ever reset. So that means that there would need to be some multiple of 7 steps (7, 14, 21, 28, etc.) to get all the way around the contact board. I bet Gottlieb didn't make a stepper with a multiple of 7 steps. They probably did make one with a multiple of 15 steps though (15, 30, or 45 steps). So rather than making a special gear just for Sky Jump they may have wired an extra contact to the 7th position every other set to make a total of 15 steps (1-7, 1-7, plus an extra 7). Then they could use a more common stepper gear. So how many contacts are there in any given contact ring? Is it a multiple of 15?
The schematic doesn't show this, probably because only every other 7th position takes up two steps.
You could test this theory by checking the unwired contacts to see if they're wired to their neighbors.
So maybe you didn't need to do the extra cleaning, but no harm, no foul, and I bet it will run longer before the next issue now.
