(Topic ID: 262022)
Multiple problems - Bally EM night rider
By Kallek
1 year ago
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Kallek
#1 1 year ago
Hi,
Used to fixing SS games and now bought my first EM. Love the mechanics but I have a bit to learn still.
My night rider has some starting issues.
1. When starting the machine it’s lights up and nothing more. Should a EM reset upon power on?
2. When pressing the start button the game tries to reset but just skips to the next ball (without even shooting the ball to the shooter lane). After each “ball” I get some points. After the 5-balls skips trough, wich takes approx 5 secs I end up with the same ending score 21000 points and the game goes over to game over-mode.
I’ve cleaned and adjusted the switches on the scoring wheels and cleaned all the Jones connectors. I guess I have some more cleaning to do but do you guys have an idea what would cause such issues?
#2 1 year ago
Here is a link to the manual on IPDB. Start sequence is on P. 3: https://www.ipdb.org/files/1677/Bally_1976_Night_Rider_Manual.pdf
and here is a link to Clay's excellent guide to EM repair. Bookmark!! http://www.pinrepair.com/em/index1
#3 1 year ago
1 EM's light up when you turn them on (or hit the left flipper button). They reset when you hit the credit button or add a coin. So that's alright.
2. Since you said AFTER each ball, it sounds like your "points" are coming from the bonus unit. The bonus shouldn't count down until a ball enters the outhole.
Make sure your outhole switch isn't stuck on. Check the Bonus unit zero position switches and switches on your ball index relay. And make sure you don't have any stuck on playfield switches, especially any that add bonus points.
#4 1 year ago
it may be a slam-switch that's part of "the time delay circuit" ... uses a #455 lamp (flasher bulb) (last page on manual)
a friend of mine had a similar situation and it was the "ball tilt" above the regular tilt bob.
an EM doesn't reset when powered on like a SS they reset after powered on & coined-up
#5 1 year ago
Thank you all for suggesting things!
Edednedy seems to be right about the bonus wheel. I resettled it in normal position and now everything is zeroing out but...
Still no ball showing up in the shooting lane, no flippers and no nothing on PF.
Well, I’ve only spent about 30 min on the machine today so i guess it’s all about cleaning more stuff. I really hope to get it going, it will be a present for my dad on his 60th birthday. I still have a couple more weeks to go and I hope I can make it.
My aim now is getting the pin to “boot” allright and the get on with the PF that needs some work. But overall it’s in rather nice shape, esp for being 45 yrs old.
Thank you all again, really great forum!
#6 1 year ago
So, a little progress is made.
Now the game kinda starts a game, ball kicks out, score wheels resets, flipper, bumpers, slings etc. works. Allt this got fixed after i cleaned the cabinet connectors in the rear end of the "under the playfield board" a 2nd time.
But the scorewheel keeps spinning and the top saucer and the drop targets keeps resetting...
Any ideas?
#7 1 year ago
Quoted from Kallek:
If you mean that a particular score wheel keeps advancing when trying to reset, check the switches on that score wheel for proper adjustment. You can compare with the switch adjustments on another working score wheel.
#8 1 year ago
Quoted from HowardR:
Sorry, i mean the score motor under the PF. It keeps spinning...
#9 1 year ago
Quoted from Kallek:
How far is it getting in the reset sequence in the manual?
Also, which of these switches is giving it continuous power?
#10 1 year ago
Also, which of these switches is giving it continuous power?[quoted image]
Will check this tonight - it is affecting the bonus stepper unit (see below) Thnx.
If I manually advance the bonus stepper wheel one step after hitting the credit button it stops. See pic for position before stepping it forward. Is this the right “default” start setting for the bonus stepper? It seems to be one pin off? The bonus wheel is spinning counter-clockwise in the picture.
#11 1 year ago
Ok. Found the problem. The advance bonus stepper coil had a wire that was broken and shorting. Wound off the wire one turn and soldered it back to the lugs. Now it works allright! Se pic.
Next problem: can only add one player. When adding another player the score motor starts (register) but when 1st player drains it never advances to the next player... ideas?
