Quoted from mbelofsky:Initial observations: (I’m sure you all know but from a new person maybe it will help others.)
1. There should be a minimum height to own the game. I’m 5’7” and struggling to lift the playfield over the sides. Maybe it will come with practice. (I do work out.)
There are at least two things you should do with your P3 without fear of getting shamed:
1) Absolutely tweak the operator settings to make games as fun as can be for your household
2) Use a step stool or platform if necessary to make it easier to swap playfields.
2. The ball was coming out of the trough on the left and bouncing and not close to top flipper. Picture with red lights show I reinserted the playfield with the metal guide behind the flap. I took out the playfield a second time. (Good practice) and lined up the guide correctly as shown in the picture with game off.
During shipping (machine on its back), gravity is trying to pull the playfield away the mating points (side target rails, latches, etc). Since there purposely isn't much overlap in the rails, the playfield rail can slip behind the side target rail during heavy vibration. It's definitely a good idea to check the seating of the playfield before playing after traveling.
3. The leftmost connector under that black box in the back was a pain to take out. I thought I’d break the wires but it finally came out.
I think WAMONH has the least space around the playfield connectors of all of our playfields so far. That coupled with the friction of new connectors makes it a little tough the first couple of times.
8. Sitting here listening to attract mode and the subwoofer that comes with it sounds amazing. (My Gameroom is 20’ x 13”.)
I laugh when people ask if they can turn off the attract mode audio because it's always due to the logo clip taking them by surprise. I *love* that clip! (and yes, there's an operator setting to turn off attract mode audio: Settings -> Audio)
Enjoy it!
- Gerry
https://www.multimorphic.com
