I am finishing up my restoration on BK2K and I want to add multi stage flipping (press button further for upper flipper, lower fires first but upper doesn't have to)
I bought the multi stage switch stack, and I just need to make sure I understand how the flippers in BK2K work before I wire it up and it explodes.
As far as I can tell since I sadly cannot read schematics (need more electronics classes) :
the lower flipper has a switch in the EOS stack that provides power to the upper flipper?
The flipper button provides the ground to finish both flipper circuits on separate wires?
If these are both true, could one not remove the power switch, making a permanent connection, and use a multi stage flipper button stack to complete both circuits at separate times as desired? Would powering the upper flipper at all times cause problems? Most flippers always have power right? I've never heard of one that works like this.
