This is that switch in the previous clip you sent I believe. Yellow/black and black. Normally closed.
Quoted from ArgosySK:Thanks for the update.
So we know the following.
At end of ball the bonus unit reset works and score points and the bonus zero relay triggers the bonus unit step.
If you tilt the onus unit rest works and the the bonus zero relay trigger the bonus unit step up.
So the failure is restricted to the beginning of game set up managed by the reset Relay.
The Bonus does count down to zero on reset.
The question becomes does the "Bonus zero" relay fire at the beginning of a game?
If it does not look at this switch.[quoted image]
