I've been thinking and thinking about how I am going to do the wiring. I found a source for cloth wire that will work, which is fantastic. Unfortunately, I need to use 22 gauge wire, which is much smaller in diameter than the 20 gauge or so that was used originally. I need this smaller wire because the boardset I'm using relies on .100 connectors. So very small. My long wire runs, therefore, have to be 22 gauge. Shorter wire runs could be normal 20 (or 18?). This means that I should only need the cloth-wrapped wire to my coils, and to my motors/relays. Pretty simple, still. I may also have enough cloth-wrapped excess wire to do this without additional (we'll see!).
I think I will need to stripe the plastic wire myself, with my built-in labor (kids). I have six colors of 22 gauge wire to choose from, and with striping I could easily triple that amount (black and white stripes).
Colors are:
Red
Green
Blue
White
Yellow
Black
The amount of wire that I need to run is actually fairly small. Essentially one unique wire per switch, then for every 8 switches, I have a ground or common wire that needs to run to the switch banks. Coils are similar. Distance is between each female Jones Plug and the back board.
I have the transformer to wire up, along with a service outlet, fuse panel, and two switching power supplies. I am using 48VDC to run my coils (several run via relay). I did some math and chose one with a small max amperage (read: cheap), so we'll see if it works! Really, a max current draw of a couple Amps is feasible for a couple of coil load.
The second switcher is going to control my 5V and 12V supply. For lamps that are controlled (playfield rollovers), I will be using the 5V supply to drive the 6V lamps. We'll see there, too. Brightness should be fine, but problems in the socket can cause board-level problems. 12V is needed for the switch boards, and to power the P3-Roc.
Then I need to crimp connectors and wire up everything.
Once all of THAT is done, then I can work on the meat and potatoes again - cabinet repair (corner brackets need to be cut and installed), fancy screen cover (I have a friend from up North that helped me with that - more on that later), and then I turn it on and see just how much I got backwards.
Now, before all of that fun stuff, I made a mistake on my inked version - I made a note on the pencil version on my Jones Plugs but didn't fix it before I started inking. Guess what I did wrong? Funny thing is that I stopped several times before inking and thought something was off with the Jones Plugs. Oh, well. Haha!
I am buying a white-out pen after work and getting that corrected.
I have an additional two switch boards on the way and an additional driver board. My final (ha!) design includes more coils, and the second driver board won't really be used at the beginning, but I will be adding to it as I go. I needed the two additional switch boards to handle the playfield Jones Plug selection and a few more special switches (up to 28 holes, etc).
So that's all the work left until my prototype is put together enough to test. After that, I'll be adding things like speakers, and working to isolate sounds to record. I have ideas for that as well!
Then I have one more artistic challenge - cabinet stencil and spraying.
After all that easy stuff, it'll be back to programming.
Sanity check: does that all sound reasonable?
