Aloha,
Disclaimer: I'm a total noob.
I'm still having issues with my display. Display version screen keeps popping up randomly now, over and over again during gameplay and attract mode. Someone suggested replacing the CPU to Display ribbon cable, so I did that and it didn't fix the problem. I reseated all the connectors on the display driver board and also the display-related connectors on the MPU board. No change. The problem has gone from bad to worse... Today I removed the ROM3 and ROM0 chips from the display driver board and sanded some corrosion off of the legs and reseated them (notch to notch). I also did this with ROM C5 on the MPU. Still no change in behavior.
Anyone know what might be causing this issue? Seems like the display keeps wanting to continually reboot, or at least that's my hunch judging by the startup message constantly popping up.
Please help!
Thank you
#msf #frankenstein #dataeast #maryshelleysfrankenstein
