All lights connected to the Aux Lamp Driver PCB (A9) do not work. This is most noticeable in the pac-maze; none of the red lights work. I have traced it down to no CLK signal on U1 (A9). This signal is generated on the MPU board, a signal called "Lamp Strobe #2". The machine boots fine, I can even watch the boot sequence (the green led) signal at the CLK signal on U1 (A9) via the o-scope (it's all connected); however, once the boot cycle is over the Lamp Strobe #2 goes low and no activity is observed on the o-scope.
Just to rule out an issue with the 6821 port expander I swapped U10 and U11 on the MPU (A4) PCB. The machine behaves the same. Inspecting pin 39 (CA2) on U11 with the o-scope the signal is inactive. Inspecting the same pin on U10, I see activity. Reading the datasheet for the 6821 I suspect Bally has pin 39 configured as an output and then sometime after boot-up configures the pin 39 (CA2) to mirror pin 25 (E). This is just a theory and would love to know if someone knows this for a fact.
Inspecting U10 pin 25 (E) with the o-scope I see activity. Anyone have any suggestions of things to check?
