Hi got a mr mrs Pac-Man and everything works except the right flippers it’s getting power and moves freely but had a lot of soot on it and the coil sleeve looked rough. So I put in a new coil and it still doesn’t work I also ordered a new eos switch but couldn’t help try to see if it worked. So now I’m going to change the switch but am not sure if I have it right as I think the switch is the real problem. The flipper arm doesn’t make contact until the second set of switches. Here is a pic of the old switch still in the game and a pic of how I think the new switch should go. Is the old switch missing a leaf on top that should push apart the second and third?
Does the wires look in the right spots?
Do I have the new switch in the right order?
Hoping to get this running but have to wait a day or two to try anything else cause I blew the small fuse on the solenoid driver board and can’t find one locally.
Thanks for any help
