(Topic ID: 242572)
Mr and Mrs Pacman without coils. Tilt stuck...
By wylcot
15 days ago
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 9 days ago by wylcot
#1 15 days ago
A friend brought me his Mr and Mrs Pacman because when game starts, the coils won't work.
So I checked in test mode, and switch 15 flickers. So the tilt, then.
But I've tried disconnecting them, and nothing seems to do.
I've tried my CPU board (which works fine) and the problem is the same.
I spent my afternoon trying everything I could, but I'm stuck here...
Any idea will help !
#2 15 days ago
Cut a leg off of those disc caps on the tilt mechs and see if the problem goes away.
#3 15 days ago
Quoted from Xenon75:
I've tried that. And unsoldering some of these wires. But nothing changed yet...
#4 14 days ago
Quoted from wylcot:
Did you remove the disc caps from ALL THE TILTS IN THE GAME?
#5 14 days ago
Quoted from snyper2099:
Do you mean, at the same time ?
I may not have done that.
Anyway, at some point, I think i'l just disconnect everything and start reconnecting every wire one by one
#6 14 days ago
Go into switch test mode.
When you see the number 15 flashing on the displays to indicate the tilt switch is closed, pull the J2 connector (playfield switch wiring harness) off the MPU board live.
Do the same again by pulling the J3 connector (cabinet switch wiring harness) off the MPU board live.
Depending which connector stops the switch closure will tell you if it's the playfield tilt or cabinet tilt to concentrate on.
#7 13 days ago
Quoted from Quench:
So there is a playfield tilt???!!!!
I was wondering why there was a "(3)" after "tilt switch" in the manual.
Well actually, I was wondering if the 3 were the 3 on the picture...
Definitely where I'll have a look next time !
#8 13 days ago
When I first got into the hobby, I had a MMPM and a tilt issue where hitting a drop target would cause the game to tilt out. The issue went away when I replaced the 5V filter capacitor on the solenoid driver board and added the jumper enhancements. I figured a flaky 5V supply was the culprit.
#9 13 days ago
Quoted from wylcot:
Yeah. Picture below borrowed from ipdb.org
#10 13 days ago
Quoted from Eric_S:
Quoted from Quench:
ahaaa !
My friends, you are a breath of hope in this rainy month of May !
#11 9 days ago
So that 3 tilt, the one under the playfield, was actually the problem.
Thanks for the help !
quench you rule !
Daytona Beach, FL
Yorktown Parts and Equip
$ 399.95
$ 90.00
Geeteoh Electronics
