Im finishing up a Bally Mr and Mrs Pacman, but im having a problem with the lamps flickering(I have all comet LEDs installed). When I say lamps I mean ALL the lamps! GI, insert, and even the 555's that are under the pf for the solenoid expander and aux driver boards(which are not LED). Its a light but noticeable flicker.
Heres what I have done:
Bought Siegecraft LED adapters and tried an Alltek lamp driver board, no change.
Tried Alltek and Weebly MPU, no change.
IF you bypass the triac mounted on the power supply, the lights do not flicker. Also tried shorting it to 5v as recommended by someone which means the triac is good(I hear they never go bad).
The aux driver board 555 lamp does light, the solenoid expander 555 lamp will flash on and off with the other lamps in lamp test mode.
Not sure where to go from here. Need advice, thank you.
