I am troubleshooting some playfield issues. Mainly, I have some coil/switch/matrix issues. I think.
The symptoms I noticed right away are:
- Middle Thumper not firing (thumper switch registers)
- Left Thumper activates the left sling (thumper switch registers)
- Top left orbit saucer not firing in either direction (switch registers)
- Left outlane switch not registering
- I also get random "M" callouts
- Also the left and right drop target banks don't reset.
What I've looked at:
- Shorted the coils in question via the SDB transistors (an also by shorting the lugs), and they fire. I replaced a few transistors in case they were bad. No change.
- Checked continuity of gray/yellow wire across the switch column that seemed most effective. Continuity seems good to the MPU J2-3 pin.
- Repaired the wiring on left outlane/inlane because I think the switches were wired wrong. I will include a picture here of my fix. I don't think I ruined anything.
- Severed the caps on the bumpers and saucer rollover (same switch column)
- Verified all fuses unblown
So far no real changes.
The machine has an Alltek MPU, everything else looks old. I did replace the connectors on the SDB and replaced the C23 and C24 cap, as well as a new fuse. Will replace C26 when it arrives later this week.
Contemplating what to try next. Suggestions welcome! Cheers.
