Troubleshooting mpu board on wpc89 machine.
Board don't boot when connected to machine, leds D19 and D21 are solid lit and D20 is out.
On bench (with external power), all 3 leds D19, D20 and D21 are solid lit.
I wonder how the 3 leds should behave when nothing except power is connected to board (on bench)?
Not sure if the board is booting up or not?
On bench, I logic probed address/data lines everywhere (including the ASIC), following the fantastic Sascha V. layout.
Got this:
- "Address CPU" lines A0-A15: A0 is stuck low and A1-A15 are pulsing.
- "Data CPU" lines D0-D7: All Data lines (D0-D7) are stuck high!
- J202 Data lines D0-D7: All Data lines are stuck high.
- "Switch jmp/dip" Data lines D0-D7: D0 is stuck high, while D1-D7 are stuck low.
Also, the processor at U4 do get a bit warmer than the other chips.
Not sure if these are expected behavior or not?
