hello,
Thank you for your comments. Indeed I am not very experienced. Fixed some GI circuits and also replaced solenoid board transistors. I have already read carefully the documentation you sent me via link.
There are 2 approaches: either I go to school and slowly practice on trial material over 2 or 3 years, as you are saying, or I try now and do my best. The worse I could do is to kill the board. Which is not a big issue, I purchased this pin for parts initially. Also this board has other weaknesses.
If things go wrong, I still can purchase a new board, which in my situation is less expensive than sending it for repair. For the past 10 pins I renovated, sending boards for check and repair is what I did at very high cost, because executed abroad. I have not found that service in Belgium.
Do I get a new board without trying ? Do you consider that type of problem as not feasible without experience? . I am open to that and your input is appreciated
