(Topic ID: 222344)
MPU 100 Missing Capacitor
By oldschoolbob
2 years ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by KenLayton
#1 2 years ago
I’m working on a Stern Lectronamo. It wouldn’t boot in the game – missing 5 volts at the MPU. I have 5 volts at J4 so I pulled the board out and tested it on the bench. It booted fine. I need to replace the headers so I was looking it over so see what else needs to be done. That’s when I noticed that C80 is totally missing!
This board has been worked on before but I see it needs a lot of help. I just thought it was strange that it boots with missing parts.
Bob
#2 2 years ago
That's a picture of a Bally -17 MPU board. Capacitor C80 should be a .01 uf @ 100v.
#3 2 years ago
You mean it's NOT the original board? I'm shocked. Just kidding - seldom do I find a game with the original boards. But how can you tell it's Bally and not Stern?
#4 2 years ago
C80 missing is not a big deal, it's just a filter cap to clean up the 5v supply slightly. There's 8 of them around the board so if one fails not much happens.
#5 2 years ago
Quoted from oldschoolbob:
M100 just look different. Traces with rounded edges, darker colored pcb and other stuff
#6 2 years ago
If it hadn't been sanded off to get at the corrosion there'd also be a part number on the bottom right
#7 2 years ago
All the Bally boards are clearly drawn using CAD (Computer Aided Design) and all the traces are straight lines with angular turns and everything nicely lined-up. Stern actually stole the board-designs, re-drawing them by hand so you get swoopy/curvy traces instead. Because the designs were basically copied (and Stern did_ get sued by Bally over this!) almost all the boards are direct, drop-in compatible, the major exception being the MPU-200 vs. AS2518-35 (though these boards can easily be converted either direction).
#8 2 years ago
Stern boards are colored dark blue whereas Bally boards are green.
#9 2 years ago
$ 49.99
PinballElectronics.com
$ 6.00
Siegecraft Electronics
$ 149.95
Allteksystems
$ 149.00
$ 65.00
Cabinet - (Alt) Translites
Judge Dredd Translite Out of stock
$ 95.95
$ 8,800.00
Stealth arcade
Medisinyl Mods
