I spent most of the day working on the practice board. Dang those parts are small. First attempt was a couple of diodes. There're round and very hard to hold in place. I have some flux paste that (I think) has solder in it. That seemed to work a little better on the small parts. I also tried different soldering tips.
Then I tried some capacitors and resistors. Not much better. I need a lot of practice.
Next I tried one of the IC's. I followed Dave's video and it came out pretty good.
So far I've found the round chisel point tip works pretty good for me - especially on the IC. The flux paste (with solder) works good on the small parts but I don't think it would work on the IC's. Liquid flux worked fine. I've always soldered by heating the part and the pad and adding solder. That don't work so well with these parts. So I add the solder to the tip then touch the the joint. The 0.015 solder is small but the 0.031 works just as well with this method.
I'm going to practice more the next couple of days then maybe I'll be ready to tackle the real work.
Bob
