(Topic ID: 253732)
MPU 100 Don't boot on first try
By oldschoolbob
    There are 252 posts in this topic. You are on page 4 of 6.
    #151 4 years ago
    Time to call it a night!
    #152 4 years ago
    if I change the sweep time I think we'll lose the pulses.
    Instead I moved the window and got 4 shots.
    pic_9_8 (resized).jpgpic_9_8 (resized).jpgpic_9_9 (resized).jpgpic_9_9 (resized).jpgpic_9_10 (resized).jpgpic_9_10 (resized).jpgpic_9_11 (resized).jpgpic_9_11 (resized).jpg
    #154 4 years ago
    The purpose of capturing the CLK signal was to be able to determine exactly when the scope wanted to read the incremental encoders.
    If we can't do this effectively then maybe need to try another crude approach.
    We know that when the "C" control signal at U2 pin 9 goes high, the scope is in the phase of reading the incremental encoders. So using U2 pin 9 going high as the trigger, what happens on the FPMUX signal at U2 pin 3?
    You're going to need to connect both oscilloscope probes. Ch1 on U2 pin 9 and Ch2 on U2 pin 3.
    The problem with this approach is we don't know which encoders data we're looking at.
    #155 4 years ago
    Quoted from Quench:
    Both at the same time?
    #156 4 years ago
    Quoted from oldschoolbob:
    Yes both at the same time, because when U2 pin 9 goes high that's when one of the encoders are being read (with this approach we don't know which encoder). So we're looking at what info is coming out of U2 at that time. The encoders should be reporting a mixture of open and closed switches going into U2.
    #157 4 years ago
    Quoted from Quench:
    I knew you'd say that.
    It MAY be possible for me to hold both probes at the same time (not easy but possible) but I can't press the save button. Maybe my wife can push it but it'll have to wait - she went to bed already.
    I'll need to set the time base and voltage before I attempt this. Any idea what I'll need to set it at?
    Ever think you guys would be teaching long distance? The education I'm getting is amazing.
    Thanks guys.
    Bob
    #158 4 years ago
    What about a third probe? (I'm not kidding ). How gymnastic are your fingers?
    Ext Trigger input connected to the FPCLR pin 2 of U1. This tells the scope and us when the read process is beginning and to start tracing.
    Ch1 input connected to the FPCLK pin 1 of U1 which we can use to tell us which switch is being read at a certain point in time.
    Ch2 input connected to the FPMUX pin 3 of U2 which tells us the state of the switch (or encoder we are interested in) being read.
    Somebody rotates the first encoder (Volts/Div CH2) and we watch if the switch state out of U2 is changing.
    Getting complicated huh?
    #159 4 years ago
    Answering your previous question, voltage on channel 2 make it the same as channel 1, time base probably around 24us.
    #160 4 years ago
    Quoted from Quench:
    Pushing the record button would be about her limit.
    What are you doing tomorrow? How soon can you get here?
    #161 4 years ago
    Let me book a super jet now and I might make it in time..
    #162 4 years ago
    Sorry, I'm confused...
    Bob is trying to see 63 or 64 clock cycles, correct? Then, ideally, maybe see a delay. Bob's plot below is in the nS range, so the plot he captured is a single clock cycle, no? Why doesn't he increase the sweep time in order to count the pulses?
    Might be a moot question if you are try to capture a specific event.
    Regardless, finding a proper trigger would be the way to go if he can somehow get a probe on it.
    #163 4 years ago
    Quoted from mbwalker:
    Hey,
    Have a look at the diagram I drew on the following post which shows all the switches configured in the matrix. I left off the U1 chip that controls both 74HC4051 chips.
    https://pinside.com/pinball/forum/topic/mpu-100-don-t-boot-on-first-try/page/3#post-5284901
    If you download the schematics Bob linked and mentally put U1 from page 7 onto my diagram, you should get an idea how the switches are read and that it takes 63 clock pulses to go through the matrix.
    https://www.mikrocontroller.net/articles/Datei:Hantek_Tekway_DSO_MSO_hw1007.pdf
    The assumption has been that the CLK signal we're trying to measure, pauses at the end of each 63 cycles which may or may not be true.
    If yes we have some way of knowing when the process starts and when each switch is being read.
    If not we need to trigger the scope on the "CLR" signal going to U1 to know when the circuit is being reset to read the first switch state.
    Bob needs more hands to hold all the probes in place or find a way to connect them to the board by soldering wires to the pins being probed.
    At the end of the day, there's 3 surface mount chips controlling these switches/encoders and U2 on the board is the first suspect with its "C" input pin potentially not working.
    One way or another Bob probably needs to replace it and if unsuccessful maybe the other chips. If replacing the 3 chips doesn't fix it then it's potentially an issue at the FPGA 1 chip on the main board which could mean it's game over.
    #164 4 years ago
    I’m not in the shop yet.
    Didn’t we decide the problem is probably U2 P9 (C) is being held low causing X4, X5, X6 not to work properly. If I check U2 pins 9 , 10 , 11 and they all show basically the same Then can we assume U1 is doing its job? And if I compare U2 P9 ,10,11 to U3 P9, 10,11 and they look about the same also means U1 is working?
    If everything looks right on those pins – then the problem has to be in U2. Right?
    Quench, to answer your question from a while back – No, I don’t have a hot air gun. Expensive tool for just one job and I doubt I’ll work on SMDs again (I hope). I was thinking of using ChipQuick. The problem I see is installing the new chip. Holding it in place while soldering the legs. Would BluTack (silly putty stuff) or temperature resistant tape work?
    I’m heading down to the shop soon.
    Bob
    #165 4 years ago
    U2 P9:
    U2 P10:
    U2 P11:
    U3 P9:
    U3 P10:
    U3 P11:
    It looks like (to me) we have activity on all those pins. They are getting their signal from U1. So we can assume U1 is working. We can also assume U3 is working because all switches going through U3 are working.
    Could it be something in U2 is causing "C" to be held low? Or something in U2 is broken and not letting the signal get out?
    I'm no expert but this is just my guess.
    Bob
    #166 4 years ago
    U2 P1:
    U2 P2:
    U2 P3:
    U2 P5:
    I don't know if this means anything but the traces on P1, P2, P3 seems to be moving - like it's constantly changing. The trace on P5 is never changing. It's the same every time I test it. Does that tell us anything?
    Bob
    #167 4 years ago
    Kind of, you're getting external activity on U2 pin 9 coming in, but internally, U2 pin 9 might be open circuit - this is the assumption since U2 pin 9 needs to go high to pass the rotary encoder signals through.
    The waveforms you posted for U2 pins 11, 10 and 9 all look good to me. You should notice that pin 11 is switching twice as fast as pin 10 who is also switching twice as fast as pin 9.
    Essentially, the way U1 is wired yes. But your U3 pin 11, 10 and 9 pin waveforms don't look right. They're not uniform like those from U2. Now the U3 pins 11, 10 and 9 are controlled by the same U1 signal (pin 5) driving the suspect pin on U2 pin 9.
    Download the U1 "74HC393" datasheet. Have a quick read of the description and then look at the function table which will tell you what happens on the outputs with each active CLK signal change. This chip is designed to change outputs on the falling voltage edge of the CLK signal. We call this a falling edge triggered clock. A logic high voltage on the CLR signal on this chip resets all outputs to logic low voltage state. i.e. when this happens both U3 and U2 are connected to the very first switch in the matrix.
    https://www.ti.com/lit/gpn/sn74hc393
    Hot air guns aren't that expensive but you can do this with a soldering iron. My method back in the early 90's was to solder the corner pins so the chip is held in place, then flood solder over all other pins. Using the thinest solder wick, remove any solder bridging the pins. It actually worked quite well with nice results. Flux helps a lot with this because it makes the solder less likely to bridge when you're cleaning up excess with the solder wick.
    Of course you need to remove the chip first, probably cutting each pin with a sharp pointy nose cutter then remove the remaining pin debris with your soldering iron and solder wick.
    Pins 1 and 2 of U2 connect to the rotary encoders which are reporting their bit positions. While the activity looks unusual, they should be changing.
    Pin 5 goes to all the push button switches on the encoders. Since you're not pressing any of them, they are all responding with open circuit. Press a few of the encoders push button switches while analysing pin 5. Does the waveform change?
    #168 4 years ago
    Bob, see the two diagrams below.
    I've configured both the U3 and U2 A,B,C input pins - refer to the function table.
    First picture shows U3 C,B,A pins configured as Lo, Hi, Lo respectively. This makes U3 internally switch the X2 pin to the X pin which is grounded. So in the switch matrix, you can see the column of switches on X2 are now connected to ground.
    U2 C,B,A pins are configured as Hi, Hi, Lo respectively. This makes U2 internally switch the X1 pin to the X pin which is then sent to the mainboard via the FPMUX signal. So in the switch matrix you can see the row of switches which are now connected to U2 X1.
    The junction point of these two selected column and row lines is the front panel switch "F0" (Function 0).
    If the F0 switch is being pressed, then the FPMUX signal reports logic low zero volts to the mainboard that the switch is closed.
    If the F0 switch is NOT being pressed, then the FPMUX signal reports logic high 3.3 volts (via the 10k pullup resistor) to the mainboard that the switch is open.
    U1 controls the state of the A,B,C input pins to both the U3 and U2 chips. U1 is controlled by the mainboard which via the CLK signal steps through the switch matrix.
    The second picture I've configured the U3 and U2 A,B,C input pins to look at one of the rotary encoder lines of the "V0" control.
    #169 4 years ago
    I've read over all the posts regarding this scope and this is about the best advise.
    Quoted from Quench:
    What I need to do is order some 4051's and 393's. They're cheap so I'll get several incase I screw some up. But there must be a zillion different sizes and shapes of them available. I have no clue what I need to order.
    Below are some photos and some rough measurements. Can someone please tell me what to order?
    Bob
    S20191028_0003 (resized).jpgS20191028_0003 (resized).jpgU1 size (resized).jpgU1 size (resized).jpgU2 size (resized).jpgU2 size (resized).jpg
    #170 4 years ago
    Can you post a more closeup clear picture of U2? It almost looks like some of the pins on the left side aren't soldered properly.
    When you're not sure of the package type, download the datasheet - you'll find details there:
    Your dimensions roughly match the "TSSOP-16" package.
    #171 4 years ago
    Bob,
    Do you have a micrometer? If you cant read the full part number on the IC, then just measure.
    #172 4 years ago
    Here's a couple more photos. I'm pretty sure it's soldered securely. I think that's glare from the lights.
    I do have a micrometer but it was easier to get in there with my vernier caliper. The drawings above were the best I could do. (dang, that's small)
    I agree the TSSOP is the best match. But when I went to order it, it don't say what package. Just see data sheet - and that shows dozens of sizes.
    Is Mouser the best supplier? Where would you order from?
    Bob
    IMG_3975 (resized).JPGIMG_3975 (resized).JPGS20191028_0006 (resized).jpgS20191028_0006 (resized).jpg
    #173 4 years ago
    I'm a big Mouser fan. Digi-Key is good also.
    #174 4 years ago
    Thanks Dave
    I think I bought from Mouser before but their site is very confusing for a dummy like me - Seems like a great place for professionals though.
    I might look a digi-key.
    Bob
    #175 4 years ago
    I just looked at digi-key - 5,151 items (207 pages)
    https://www.digikey.com/products/en/integrated-circuits-ics/interface-analog-switches-multiplexers-demultiplexers/747?k=&pkeyword=&sv=0&sf=0&FV=-8%7C747&quantity=&ColumnSort=0&page=1&stock=1&pageSize=25
    I guess a real professional could filter out what he needs - but I have no idea what to look for.
    Mouser is about the same.
    We need an electronics store for dummies.
    #176 4 years ago
    I think it’s more complicated to find the correct part than to figure out what part is bad.
    Here’s the 4051 that I think I need.
    https://www.mouser.com/ProductDetail/595-CD74HC4051QPWRQ1
    The specifications show Package/Case = TSSOP-16. The data sheet shows TSSOP-16 is pretty close to my measurements. I think this is the correct part.
    Here’s the 393 that I think I need.
    https://www.mouser.com/ProductDetail/595-SN74HC393PWR
    The specifications show Package/Case = TSSOP-14. But the data sheet doesn’t show TSSOP-14. The data sheet shows PW (R-PDSO-G14). Which is pretty close to my measurements. (See screen scan). Is this the correct part? Is PW (R-PDSO-G14) the same as TSSOP-14?
    You guys that do this every day are amazing.
    Bob
    #177 4 years ago
    It's a TSSOP-14 package. The "PW" letters is Texas Instruments way of including TSSOP-14 to their part number which for them becomes 74HC393PW.
    On a quick look I like the Nexperia brand parts which have low capacitance. You should be fine with the two Texas Instruments parts you linked from Mouser.
    But gee they're pretty small. I hope you've got a decent magnifying glass.
    #179 4 years ago
    When you compare the price of the parts (0.38 to 0.86) to the cost to ship (7.99) - I may as well get plenty.
    I looked at Nexperia parts but which one do I need? Or which one is best? I'm sure there's a difference but I sure don't know.
    4051:
    https://www.mouser.com/ProductDetail/771-74HC4051PW-T
    https://www.mouser.com/ProductDetail/771-74HCT4051PW-T
    https://www.mouser.com/ProductDetail/771-74LV4051PW-T
    https://www.mouser.com/ProductDetail/771-LV4051PW112
    I'm listing these 4051 grouped by type:
    These two are 74HCT where the 'T' indicates they are TTL version and only run at 5 volts - you don't want these.
    These two are 74LV where the 'LV' indicates they are low voltage version (between 1 and 6 volts) you don't want these.
    These two are 74HC (same spec your board has) which is what you want. They are identical, the only difference is how they come packaged from the supplier. The first one comes in tubes and the second one '-T' comes in tape reels. Choose whichever. The tube ones will probably be easier to store away.
    Ditto for the 393 parts, you want 74HC only - first one is tube, second one is tape reel.
    https://www.mouser.com/ProductDetail/771-HC393PW112
    https://www.mouser.com/ProductDetail/771-HC393PW118
    Since their cost is peanuts get some Texas Instrument ones too.
    That's what I been worrying about for the last week. I'm thinking about getting these:
    https://www.amazon.com/gp/product/B00OK0MAX6/ref=ox_sc_act_title_1
    Funny I was looking at buying those a month ago but got something else and not sure I made the right decision. If you get them I'll be interested on your thoughts. It's got more than enough zoom I think.
    By the way, I find soldering these small things outdoors in daylight helps a lot with visibility - best light conditions..
    #180 4 years ago
    Bob,
    Removing/replacing the 4051 should be rather painless.
    1) First off, note the pin 1 mark, dot, etc.
    2) The simplest way to remove is to use two irons with a wider (chisel) tips, or maybe just a normal tip placed at an angle. But not high wattage! It won't need much heat to flow the solder - it's just a little part. You can actually add solder so that it bridges the pins on each side to help transfer the heat. Plus use some 63/37 or 60/40 (lead) solder since the scope is likely RHOS. Lead free solder melts at a high temp is somewhat of a PIA.
    3) With an iron on each side and solder melted, the part will easily slide free. Shouldn't damage any traces. Don't force it, it should slide off like butter. Watch out for the bypass chip cap right next to the IC. Thank goodness there's no thermal pad to unsolder on the bottom of the part - that would make it a lot harder.
    4) Use solder wick to clean up excess solder on the pads. It will probably be a mess due to the extra solder, but the solder wick will take care of it.
    5) Place the new part on the pads, use just a small amount of solder on opposing corners to anchor and center up the part. Solder the remaining leads, and then correctly solder the first two joints used to anchor the part. Too much solder? - just wick some off. Check the pin 1 mark.
    Easy peasy. I'm an old fart and have been using surface mounted parts for many decades. For the most part, I'd much rather work on surface mounted parts than thru-hole. At work we even use 0201 (0.02 x 0.01") parts and we are going smaller, but I admit I use bigger parts due to my line of work. You might want to get some thin solder.
    You might be surprised how easy it is to replace/install if you have steady hands.
    Got an old board to practice on?
    #181 4 years ago
    Thanks Quench,
    I've ordered 6 each of the 4051 parts and 3 each of the 393 parts. I'm afraid if I drop one I'll loose it.
    I have one of those magnifying lamps but could never get used to using it. I'll let you know how the glasses work.
    Working outdoors is out of the question now. We're coming into winter here - high today was 45* F - next week we're looking at 30's and 40's.
    I hope you're right. I've watched dozens of videos. My plan is to use ChipQuik to remove the old part - never used it before but it looks pretty easy.
    You, Quench, and everyone suggests tacking down the corners first. My concern is holding the part in place while I tack it down. I've had good success using Blu Tack (it's like silly putty) to hold headers straight and IC sockets flat. I'm hoping to use it to hold the part in place while I tack the corners. Or maybe use the heat tape.
    The solder I use is Kester 63/37 .031. I've had good luck using it. Do they make a thinner solder?
    Many people have said that surface mounted is easier and faster than thru-hole. I guess it depends on how many you screw up.
    Thanks guys. I'll let you know when the parts arrive. Maybe you all can stop by and show me how easy it is.
    Bob
    #182 4 years ago
    Bob
    Quickly tinning the part's lead prior to installing will help a lot. Don't need much, just a light coat. You can also add a little solder to the opposing pads so it's all set to go. Again, not much is needed - just enough to hold it in place and solder properly afterwards. Just take the eraser end of a pencil (or something similar) and hold the part in place, hit the opposing leads, part will settle in place because of you holding it in place - secured. No need to overthink it. I would think the tape would be a big PIA and is not needed.
    0.031" solder - give it a try and make sure you don't short between pins. Smaller might be better, but 0.031 is definitely OK.
    You'll get the hang if it - it really is not hard if you have halfway decent soldering skills (and you do). Too many post on Pinside about SMT being this weird and hard thing to work with since it's new to them. It's just not.
    If you're really worried about it, just buy this and practice first: A few dollars, and money well spent to calm your nerves.
    https://www.amazon.com/s
    #183 4 years ago
    ChipQuik seems to be a brand of a range of products. Which one are you referring to?
    If it's not too late get the thinnest solder wick you can. My personal experience is I always found it performed better for dealing with surface mount stuff - it robs less heat from the iron and is easier to manage. The wick I've always used is about 1mm thick.
    I put the chip into position, push down on the chip say with a screw driver so it doesn't move, put some solder on the iron and then iron onto a corner leg so it attaches to the board. Inspect the chip positioning to the PCB pads and once I'm 100% happy it's centered, do the opposite corner leg. If positioning is still good then solder the rest. Otherwise adjust if necessary til it's right before doing all pins.
    #184 4 years ago
    Great idea!
    #185 4 years ago
    On order - thanks
    Quoted from Quench:
    https://www.amazon.com/gp/product/B0019UZP7I/ref=ox_sc_act_title_6
    I just found 0.015 on Amazon:
    https://www.amazon.com/gp/product/B076GHCZZ1/ref=ox_sc_act_title_2
    I think it's the same as what I been using but thinner.
    Quoted from Quench:
    That's strange - I have some solder wick (Radio Shack I think). I always complained it was too thin and don't absorb much solder.
    Thanks guys - maybe I can do this.
    Bob
    #186 4 years ago
    Here's Dave using ChipQuik.
    #187 4 years ago
    Interesting.
    You'll be an expert in no time
    #188 4 years ago
    That is some interesting stuff. I don't think you need that since your part is so small. In the demo the chip was huge - so that does look useful in that instance.
    On a side note, he did make a very good comment...don't drag the iron and solder wick across the pins when cleaning.. Just down and up, then move over, repeat. Also, that was a pretty good size iron for the little pads to use w/the solder wick. If I was removing excess solder, I'd use a smaller iron.
    Also, not all solder wick is created equal. Some has very little flux, and it can be a little bit of a pain to get it to wick up solder. Add some rosin flux to it if it doesn't take solder well. Good solder wick will really pull solder away.
    #189 4 years ago
    Yeah, this is the problem with some of them.
    Yes! Flux is your friend with surface mounts.
    #190 4 years ago
    What worries me most about the ChipQuik is that it mixes with the solder so every bit of it must be removed before attaching the new part.
    Mark suggested a while back to use two soldering irons. I might give that a try first.
    On thru-hole parts I usually set my iron to 650*F (344*C) Should I use less heat for SMD parts?
    I'm looking forward to getting those glasses and practice board.
    Maybe this weekend.
    Bob
    #191 4 years ago
    Maybe this weekend.
    Bob
    I thought about the residual low temp solder, but once you wick it up, it will be gone. Any minuscule amount will simply mix with a lot more fresh 63/37 and be a moot point.
    344C seems VERY hot. 63/37 should melt around 180 - 190C. I'm not opposed to applying a fair amount of heat to make the job go quickly. To me, 'not much heat and taking forever' to get the job done is by far an easier way to damage a board rather than 'hot and fast' with a little more heat - withing reason. 344C seems way too hot. WAG, but 250C'ish should be enough, depending on the tip. Hence, my comment about globing solder over all the pins to heat them up all at once with a bigger tip, and sliding the part off. Fast and done...
    #192 4 years ago
    Parts from Mouser arrived today. When I opened them my first thought was they sent the wrong parts. These are way too small. Then I went to the shop and compared them - nope - they're the correct parts OK. I sure hope those magnifying glasses work.
    The problem today is we have machines that can do this sort of stuff that a human can't do.
    We'll see.
    Bob
    IMG_3997 (resized).JPGIMG_3997 (resized).JPGIMG_4003 (resized).JPGIMG_4003 (resized).JPGS20191107_0002 (resized).jpgS20191107_0002 (resized).jpgS20191107_0003 (resized).jpgS20191107_0003 (resized).jpg
    #193 4 years ago
    Well at least it looks like you got the same brand 4051 as the original.
    #194 4 years ago
    After you get the hang of this, you will officially be known as "NewSchoolBob".
    #195 4 years ago
    You can do it! I built a few pieces of test gear for myself and the chips only came in surface mount. I managed and it was not too hard. Take your time and flux is your friend.
    #196 4 years ago
    This guy makes it look so easy.
    He says "piece of cake"
    #197 4 years ago
    to remove a smallish SMT chip with pins on two sides like shown in the picture using just a soldering iron wand style I would blob some solder across all the pins on one side. This will help transfer the heat to all the pins. Heat up one entire side until all pins are loose and the slide a wedge under the chip to lift the hot side up off of the board then let it cool off off the pcb. Then do the same on the other side and it will come off. Use solder wick or a vacuum desolder to clean up the pads.
    Its a bit of a brute force method but works for me and I can do it without damaging the board but the chip being desoldered will usually get ruined. Most dangerous part is sliding the wedge in under the chip when the first side is hot. If you lift to hard you can rip the tracks off of the cold side.
    When they are the standard outline, biggest size of SMT, flush cutters can usually snip the chip out then just clean off the left over legs stuck on the board with a de/soldering iron.
    #198 4 years ago
    One of my biggest concerns is lifting a pad. My track record hasn't been very good lately. A lifted pad on this board would be game over. I doubt it could ever be repaired. I'm leaning toward Mark's suggestion of using two irons.
    I plan on working on the practice board a lot when it gets here. Both installing and removing parts. Also thinking very seriously about using the Blu-Tack to hold the IC's in place. I'm not too sure I'm steady enough to hold it.
    Bob
    #199 4 years ago
    I received the magnifier glasses today. My first impression so far - You can't use both lenses at the same time. You have to close one eye. This may or may not be a problem but you can't get stereo vision. The biggest problem I see is the focal length is very short. About 1.5 inches (38 mm) with the 10X lense. The 25X is even shorter. (Hope I don't burn my nose). And you can't adjust the length. I would have prefered more like 6 inches focal length.
    I haven't tried these under actual workbench conditions yet. The practice board should be here tomorrow.
    https://www.amazon.com/gp/product/B00OK0MAX6/ref=ppx_yo_dt_b_asin_title_o01_s01
    Bob
    #200 4 years ago
    I've never been a very patient person. Went to the shop tonight to try the new glasses. They'll work great for inspection work but not so good for working under. The focal length is just too short.
    While I was there I decided to try the two solder irons to remove the old chip. Both irons set on 500*F. Just didn't seem to get hot enough. I tried several times but I couldn't get it loose.
    Plan B was the ChipQuik. I buttered it up with their paste and added the solder. It came right off. I picked up the solder blobs with the iron tip and cleaned it with solder wick. Then I washed it with alcohol. It looked pretty clean and I don't see any damage.
    After looking at the photos I see a couple of specks of solder on pins 8 and 16. Tomorrow I'll hit those again with the solder wick.
    One small step for man - one giant leap for Bob.
    Bob
    This page was printed from https://pinside.com/pinball/forum/topic/mpu-100-don-t-boot-on-first-try/page/4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
