Quoted from oldschoolbob:
The only pattern I see is U2 P4 , P5 and P6 are connected to the non-working pots and not connected to any switches.
Do you remember if any of those push button switches on the pots still worked? because they have U2 X5 connected to them.
Actually they are not pots (potentiometers) at all. You'll notice you can freewheel them 360 degrees so they're not variable resistors with a start and end position. Those things are what's called "incremental encoders". Put simply, their pins digitally indicate which direction you're turning the rotary control.
Here's the map for U3. Since the center tap of all the pots are connected to seven different pins on U3 and the fact the the other switches (using the same pins) are working - we can assume U3 is OK. Right?
In that case, U3 is probably ok.
I sort of understand what's going on with U2 but what I don't understand is what's driving "Enable - C - B - A"? Pins 6 - 9 - 10 - 11. Looks like 9 - 10 - 11 are controlled from U1 (pins 5 - 4 - 3).
Correct, U1 controls both U2 and U3. Your next mission is to download the datasheet for U1 "74HC393" and see what it does
Looks like 9 - 10 - 11 are controlled from U1 (pins 5 - 4 - 3). If pin 9 is held low then the problem could be U1 pin 5?
Pin 9 being held low could be U1 pin 5, BUT U1 pin 5 also goes to U1 pin 13 which then controls U3. Since we presume U3 is working ok, the problem might potentially be the input pin 9 of U2.
One last question - if the Enable pin is pin 6 and the schematic shows pin 6 going to ground - how could pin 6 ever go high?
In this circuit, pin 6 of U2 and U3 never go high. The circuit is designed so those two chips are always enabled by tying their active low "enable" pins to ground.
The other question I always have is where to connect the red clip? When the probe shows HI does that indicate it's higher than where the red clip is connected. If I connect to 5 volts and the probe says HI - does that mean it's above 5 V? And LO means less than 5 V?
Nope, the terms LO and HI refer to logic levels. The red clip is just the logic probes power lead so connect it to the power rail of the logic circuit.
Have a read of the below link which explains logic levels (OFF or ON, 0 or 1, Low or High) and how voltages levels translate to logic levels for TTL and CMOS devices. Because logic levels are a little different between TTL vs CMOS chips in the middle voltage range, this is the reason for the switch on the logic probe so it can better determine what's "LO" or "HI" (low or high).
https://learn.sparkfun.com/tutorials/logic-levels/all
Sense I'm going to be pulling out my logic probe soon, I have a couple of questions. When do you use CMOS and TTL? I know they're for different chips but the chips don't say they are CMOS or TTL.
In the old days it was easy. Logic chips with part number starting with "74" (74 series) were TTL chips. Logic chips starting the "40" or "45" (4000 or 4500 series) were CMOS chips.
The funny thing is the part number for the U2 chip is a 74HC4051. This part number is an amalgamation of both 74 and 4000 series chips. The function of this part was originally sold as a "4051" back in the day.
https://en.wikipedia.org/wiki/List_of_7400-series_integrated_circuits
https://en.wikipedia.org/wiki/List_of_4000-series_integrated_circuits
