(Topic ID: 164265)
Moving wheels
By Spider3582
  • 26 posts
  • 16 Pinsiders participating
  • Latest reply 2 years ago by goldenboy232
    There have been 6 images uploaded to this topic. (View topic image gallery).
    #1 3 years ago
    Has anyone invented wheels you could place on the legs of your machine permanently that lock so it makes it easy to slide your game out but doesn't affect the game when playing. My machines are on sliders and I hate pulling them out that way. I have wheels when I'm working on a machine but when they are lined up against the wall they come off
    #2 3 years ago
    Pinball Skates maybe. They're not permanent, but slip on and off easily. I"ve never seen anything permanent.
    http://www.marcospecialties.com/pinball-parts/PBS
    #3 3 years ago
    With the Pinball skates does all four legs lift or just the back . I can't tell by the pic
    #4 3 years ago
    So how does people move their machines. I can't believe they drag it or climb under and lift with thier backs to put wheels under Everytime. There has to be a easier whey
    #5 3 years ago
    Pinball dolly. Best money i ever spent!
    #6 3 years ago
    You can buy locking wheels that would bolt on just like the casters do. Home Depot sells them. Just find a set with long enough bolts. Add a nut at the bottom so you can still level your game.
    #7 3 years ago
    Yup, $20 for a set of 4 at HD. Do check they are the real Heavy locking one, they have 2 types by me.
    Ill take some pics, the next time Im at the property, but Im happy with the results.
    #8 3 years ago
    Does anybody have that Pinball lifter that attaches on a motorcycle lift? I seen them at Pinfest and I have a motorcycle lift. They are on eBay for 119 bucks. Just wondered how it works
    #9 3 years ago
    Quoted from Spider3582:
    Not exactly answering your question. however I would avoid motorcycle lifts. They are rather wobbly in my opinion. If you want a lift that can reach a tailgate get the 1000lbs Harbor freight lift. No need to modify the handle like everyone thinks they need to. Just go from the back, however you can still lift from the front if you put the head down. The head folded down will counter the weight. The smaller one that is also available wont reach a trucks tailgate, so don't get that one. As well, when you are done with it, the lift stores under a pin.
    http://www.harborfreight.com/1000-lb-capacity-hydraulic-table-cart-60438.html
    #10 3 years ago
    Quoted from amkoepfer:
    This.
    #11 3 years ago
    Thank you for ideas I appreciate it
    #12 3 years ago
    What I have. No modifications needed. I have had mine for over 3 years with no problems. Best money I have spent to save my back. Should last forever with the exception of maybe having to change the shock absorber at some point in the distant future if it leaks.
    ebay.com link » Heavy Duty Pinball Lift Dolly Cart Made In The U S A
    #13 3 years ago
    +3 on the pinball dollies.
    I have one in the basement, one in the garage, and one at my parents' basement. Well worth the money.
    #14 3 years ago
    Quoted from Spock:
    I go from the front. I did this rather involved mod:
    Step one:
    Stand on cart
    Step two:
    Push on cheap China steel until it bends.
    #15 3 years ago
    Yep, did two that way.
    #16 3 years ago
    Quoted from newmantjn:
    Step one:
    Stand on cart
    Step two:
    I love this, I might add some cheezeburger grease to step 1.5 as king of lowtec!
    #17 3 years ago
    Step two:
    my orange older one from harbor freight will not bend like that and i am a fairly heavy guy.
    #18 3 years ago
    They are over 200 bucks but maybe I can get a 20% off coupon
    #19 3 years ago
    The 500 lb one is 169 and should be plenty.
    #20 3 years ago
    With a 20% coupon I can get a 500lbs hydraulic lift cart for 135.00 but I might have to order it
    #21 3 years ago
    Here's my solution, ATV lift modified first with a riser box to get the height then with a tilt top and forks to tilt a game. Works very good for the shop.
    i then have a harbor fieght 500 lbs lift table for the game room to pull games in and out of the lineup.
    But yea this is permanently attached to my ATV lift, I dont own any ATVs, that would cut into my pin money
    #22 3 years ago
    I do have a motorcycle lift that I don't use for a bike anymore
    9 months later
    #23 2 years ago
    I almost bought a pinball at an estate sale, but got there too late. Still, I was worrying about how I was going to move it out by myself if I had bought it. So, a cart like the one at Harborfreight sounds like something I should get. My question is that since the table is only 17 11/16 wide and not long enough to go front to back, do you need to provide any extra reinforcement when you jack it up under the game? Doesn't seem to me that there would be enough strength in the bottom of the pin to support the game's weight.
    #24 2 years ago
    Quoted from Renouart:
    Never been a problem for me. For Bingos with the 300# head, I extend the table with 2x4's bolted to the table.
    #25 2 years ago
    Thanks, no one ever said they did something special to reinforce the bottom, but I just wanted to make sure I wasn't missing something.
    #26 2 years ago
    I simply use a set of of the plastic "sliders" that you can get for moving furniture under the feet of each pinball machine in my collection. Easy-peasy for moving them around if you're just pulling them out to service them, re-arranging them, or moving them across the room or the house.
    If I need to actually transport a game, it's not hard to take it apart (Remove 4 head bolts, disconnect the Jones plugs to the head, stow the cord, and remove the head; then take the two back legs off and slowly lower to the ground; tip the game onto its end so it's standing vertically on its built-in gliders; remove the front two legs; put on a dolly and transport to my Tahoe).
    $ 233.10
    PinWoofer
    $ 65.00
    Texas Pinball
    £ 29.00
    PinballToys
    $ 19.95
    $ 7.50
    $ 86.00
    The MOD Couple
    German-Pinball-Modular
    £ 49.00
    PinballToys
    $ 79.95
    Full Tilt Pinball LEDs
    $ 999.00
    $ 66.95
    $ 48.00
    $ 28.00
    Pin Monk
    $ 7.95
    $ 48.00
    Playfield - Plastics
    Mod Magic!
    $ 140.00
    pinballmod
    Mods for your pinballs
