(Topic ID: 266006)
Moving these metal parts from original to replacement plastic?
By ChadTower
55 days ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 52 days ago by TheLaw
#1 55 days ago
How does one go about transferring those metal parts from the original plastic to the new plastic? This is one I've never done before. Looks like heat was used, maybe, when these were inserted into the original? The plastic seems to be molded right around the metal part.
#2 55 days ago
#3 55 days ago
I've had success using a soldering iron to heat the metal, then pull it out.
#4 54 days ago
Search the forum on "bell post removal".
#5 54 days ago
I've done several games with those metal bell standoffs on Stern games. I just pulled them out. The holes in the new plastics I had to enlarge slightly to get the standoffs to fit but never had any issues.
#6 54 days ago
Quoted from KenLayton:
Thanks, Ken! I didn't know exactly what they were called. I'll do this search now.
These are definitely not coming out without some heat or grinding. The plastic is physically molded around the top of the bell post.
#7 52 days ago
Just to close this off I did manage to get them successfully removed and then embedded in the new plastics. Just took a little care and patience with the soldering iron. Nerve wracking but went reasonably smoothly. I did have to file down the top of the bell to make it match the holes in the new plastic a bit closer.
#8 52 days ago
Yeah I always drill them out, and then grind off the top....but I'm not big on patience
$ 259.95
Pin Stadium Pinball LEDs
Displays
PinballSolutions.eu
