I’m in the midst of moving the out-lane posts on my IMDN (don’t shame me). I’ve moved many of these before without issue.
The posts on IMDN appear to be threaded, and while the other holes in the playfield have been drilled, it does not appear they are threaded, which means it will take a bit of force to screw it in.
The problem is, I don’t seem to have a nut driver that has enough clearance internally to allow the post to insert far enough to get to the nut. I can use a wrench (tedious), but since the hole isn’t threaded, I can’t apply enough downward force. I may end up having to find a screw of the same size and thread to drill in, remove, and then use a wrench to get the post in.
I feel like I’m missing the right tool for this.
Suggestions?
