Hi all, I just bought my first pinball machine (a Bally World Cup Soccer), which was working fine when I picked it up, but after a 3 hour drive, seems to have some issues (damn!).
I plugged it in and turned it on, only to hear a pop, and no response from the machine. Lifting up the playfield I checked the fuse in the power supply (8A), and that had blown.
One thing I noticed was there were a couple of cut wires around the power supply (white and black) the white one was end down on the metal power supply, wondering if this shorted on the supply causing the blown fuse? (these have been taped up now, but may have been to do with a conversion from 110 to 240V?).
Using a 5A fuse in the power supply (all I had around), I powered it back up and there were a few more popping noises that concerned me, so I promptly turned it back off. Checking the power supply fuse again, it hadn't blown, so not sure where to go from here.
This is my first machine, so maybe some of the noises are normal, but I'm wondering if anyone has any suggestions for things I should check before I re power it back up so I don't fry any boards etc? (or myself!)
