(Topic ID: 217982)
Move magic screen right problems
By Bingo-poor
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 3 years ago by Terry1
    #1 3 years ago
    I’m having trouble with my Laguna Beach, moving the screen to the right. I have to hold down the right button, then press the left button in order to move the screen right. Once the screen reaches the last position lit (like D or E position) it will no longer move either direction, no matter what ball is in play or what buttons are pressed.....
    #2 3 years ago
    Check you contacts under the buttons, mine were JUST making
    contact. Burnish them up good and maybe adjust the blades to give
    you a bit more contact. Also the two buttons have a circuit in series
    i.e. the contacts of one(I believe the Left button) must be NC to get
    the right button action. So check the left NC contacts.
    Not having the schematics in front of me right now, it may be the right
    one but I believe it is the left one.
    Good luck
    Terry K
    #3 3 years ago
    You were right, I cleaned up and flipped over one of the blades (for more contact surface) on the left button switch.
    I also adjusted the left button NC switch for a little bit more tension. The right button is now working flawlessly.
    Thanks Terry !
    #4 3 years ago
    Any time "Bingo-poor"
    With all the help I have received from the people
    on this site, I will always help, if I can!!
    Terry K
