(Topic ID: 299908)
Mousin Around GI issues
By drewbo81
2 years ago
#1 2 years ago
Purchased a Mousin around and was working 100%. Right GI went out and after some investigation, I found someone hacked GI connector. Normally, I would just replace connector and wire it properly, however as you can see in schematic pic there should be 4 yellow and 4 yellow/white wires...there are only 2 of each spliced into molex connector as seen in pictures. Can someone send me a pic of their interconnect board so I may see how it is wired.
Mousin (resized).JPGMousin (resized).JPGMousin 2 (resized).JPGMousin 2 (resized).JPGMousin 3 (resized).jpgMousin 3 (resized).jpg
#2 2 years ago
You can compare to the J6 in Earthshaker. They are exactly the same GI setup and board set.
#3 2 years ago
Quoted from PinballManiac40:
DUH! As im looking at them sitting right next to one another. Thanx PinballManiac40
#4 2 years ago
Ok so I removed interconnect board removed the hack job replaced pins and made new connector...I plugged it in and now have no GI lights.
Also I saw this hack job jumper wire as well. It goes from J9-4 to J7-9. Any idea why someone would have done that?
Any help is appreciated PinballManiac40 ?
2 months later
#5 2 years ago
Happy Turkey day to all!
I have all but lower left GI working now. I have continuity from all other GI bulbs that do work to the unlit string. I checked 4 fuses and reflowed all solder on GI relay. What am I missing? What would make only those 5-6 bulbs to not light up?
I appreciate any help I can get for this one.
#7 2 years ago
Quoted from drewbo81:
Seems someone is trying to bypass a broken trace on the board. You can use your ohmmeter to check against your Earthshaker interconnect to see if it even should be there.
#8 2 years ago
Sure the remaining bulbs are good? Swap with known working ones.
#9 2 years ago
So if the game is on and in attract mode, you have 5-6 bulbs that do not light up. You say you have continuity between working bulbs, and the non-working bulbs. Are these all on the same circuit? Are you reading 6.3vac on the meter? Are these all incandescent bulbs? Same bulb number? They should be #44 or #555 type lamp. Can you send a picture of the affected area?
$ 27.00
Trade
Machine - For Trade
Gainesville, GA
$ 899.00
$ 23.95
$ 18.95
Metal-Mods
$ 45.95
Gweem's Mods
$ 5.00
Whitty Pinball Creations
$ 12.50
RoyGBev Pinball
