The cpu on the machine had acid damage so I installed a tested working board and the displays came on and were on for at least 10 minutes and then they went dark. Any suggestions on what to look for?
Everything else on the machine works except the displays. Could this be an issue with the power supply still?
Quoted from Don44:Everything else on the machine works except the displays. Could this be an issue with the power supply still?
It's the most common culprit, when it comes to the plasma displays. You are using plasma displays correct?
Ran into the same issue and for me it was the fuse for the +100 volt circuit. The fuse didn't blow, but broke due to metal fatigue.
If you metered the fuses (while off the clips), then next check the fuse clips themselves.
It could also be burnt header pins at the PSU and/or at the display board. Another possibility is the two caps for the 100 volt circuit went bad.
I replaced all of the components on the +100v and the -100v sections and I now get a faint partial display. I am getting readings of 72v and -126v. Any ideas on why it would be too high on the -100v side and low on the +100v side?
Quoted from Don44:Any ideas on why it would be too high on the -100v side and low on the +100v side?
Power leakage! Most likely a bad resistor or diode. Can you post a picture of the power supply? One of us will be able to spot the component in question.
You need at least +90v for the displays to work correctly. It's not unusual to see the negative side being up to -110v. -126v is indeed bit high though.
This page was printed from https://pinside.com/pinball/forum/topic/mousin-around-displays-stopped-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
