Name of game, manufacturer and year: Mousin' Around, Bally, 1989
Did it ever work in your Possession?: yes
Did You Run the Diagnostics?: yes, no issues come up
Where did the game come from?: a vendor that restores pinball machines
Are any aftermarket boards installed?: no
What was the last service you performed?: replaced the diverter coil
Battery Corrosion: no
LED or Incandescent lighting?: leds on playfield, incandescent flashers and backbox
Blown fuses: no
Smell: nothing weird
Obvious Past Work Performed: none
Do you have a Volt Meter?: yes
Can you solder?: yes
The left display on my Mousin' Around is missing the entire row of the top segments and the top right diagonal segments. I bought the cab about a year ago. Back then only the diagonal segment was missing, now since a month or 2 the top segment also stopped working. Can anyone guide me through repairing this? I'd like to try and fix the display before replacing it entirely with a led display. I have a multimeter and I can solder. Thanks in advance!
