I'm up to a point in my WCS where I need to lubricate the soccer wheel & goalie motors. Wondering what to use?
Though I am not familiar with the exact mechanisms in WCS, the manual recommends "MBI instrument grease" - which I hear is simply a version of teflon grease. I am a fan of no grease at all, but if you must, grease very sparingly. I just use some stuff I have left over from my model railroad hobby, PTFE Superlube grease. Its safe for things like plastic gears, its even rated food grade for incidental contact with food, for if you accidentally lick your motors
Wondering how to flush out the current old grease that's inside the gear mechs? It's a green thick substance but I assume it got that way after years of use?
Someone talked about this recently. You have to drill a small hole and add a drop or 2 of the 3 in 1 oil. This is for the soccer motor. Where are you talking about adding grease?
If you can take the gearbox apart, you can clean out the old grease with mineral spirits and a brush.
Yeah not sure how I would take it apart and back together. The taking apart would be the easy part. If I take to small motor off then there the gear hole could be big enough to rinse and re insert the grease??
Be aware there are two kinds of 3-In-1 oil. There's the light machine oil and one specifically for motors that comes in a different color bottle. I use the motor grade on my score motors and bingo machine motors.
Quoted from Toyguy:Be aware there are two kinds of 3-In-1 oil. There's the light machine oil and one specifically for motors that comes in a different color bottle. I use the motor grade on my score motors and bingo machine motors.
Yes, the blue colored bottle is the "electric motor oil" version of 3 in 1. It actually has a picture of an electric motor on it. This oil is actually 20 weight non-detergent automobile oil.
Quoted from flashinstinct:Yeah not sure how I would take it apart and back together. The taking apart would be the easy part. If I take the small motor off then there would be the gear hole might be big enough to rinse and re insert the grease??
It's possible you could pour in some mineral spirits into the hole to clean it out. Then you'd probably need to hold the tube of Super Lube against the hole and squeeze the tube (like a grease gun) to force the grease into the gearbox.
Quoted from Bugsy:What about 3M Silicone Spray?
I've used this before on non-pinball stuff. The only problem with it is that over time it seems to gum up and break down into a white dust. I've stopped using it for everything electro-mechanical. Grease type stuff is probably the safer bet, as you can wipe it off later.
Can you drill out the rivets holding the motor together and somehow use screws or something to replace the rivets to hold the motor together? Screws and nuts? I cleaned my drac motor from my Monster Bash a year ago. I think with the drac motor that screws held the motor together no rivets? I forgot it's been so long. I have a reference to the blog post I did at that time.
https://pinballsupernova.wordpress.com/2015/02/04/rebuilding-monster-bash-drac-motor/
This page was printed from https://pinside.com/pinball/forum/topic/motor-lubrication-what-to-use and we tried optimising it for printing. Some page elements may have been deliberately hidden.
