More trouble with Gottlieb Sheriff. I flipped up the reset bank and there was a piece of paper stuck in the lone switch below the SB relay. Now when the replay button is pressed the score motor only goes around 1/3 of the way and the reset bank fires and everything stops including the score reels mid reset. The playfield has some lights but no ball is kicked out and no features work. I also noticed that the hold relay is not pulled in. When I manually hold in the hold relay while pressing start the whole playfield goes nuts, all chimes sound, and the flippers work till I let go of the hold relay then everything stops. Anyone got any advice to wake this thing up?
