(Topic ID: 267534)
Monte Carlo System 80b GI issues
By muggy75
2 years ago
  • 94 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by Bax1
There are 94 posts in this topic. You are on page 2 of 2.
#51 2 years ago
Let’s start with the easy part and check continuity between the switches they are connected to. If one switch is out and the column are good, it’s more than likely a wire
#52 2 years ago
Quoted from Chisel:
Hi there, I didn't read every post but if your ramp is still not working it could be the 2N5879 transistor that's under the playfield between the flippers right at the bottom of playfield under the apron. This fixed my non working ramp. If it's bad here's a replacement: https://www.greatplainselectronics.com/proddetail.asp?prod=2N5884
That was the problem. I had fixed it a few days ago. I appreciate the info.
#53 2 years ago
Quoted from Bax1:
I have circled what is not working and found them on the schematic. Any ideas?
#54 2 years ago
Ok so check the top right pop bumper and make sure it is working. if that is not working that whole column is out and we need to trace it down why and where it would go.
#55 2 years ago
Quoted from Bax1:
so the bumper works as it should
#56 2 years ago
ok if the pop works, i would start with continuity test going from one end of the wire to the next. not sure if they go to a connector or go straight to the board. good thing is you have the color decoder there to tell you what the wire is. so like sw 31 is brown.
#57 2 years ago
Quoted from Bax1:
I am feeling pretty stupid, but I cannot find the other end of the wires. Like 31 I lose it in the bundle then it seems to disappear. Need to walk away. Lol
#58 2 years ago
lol don't get discouraged, it is easy to lose where they go in the bundle. so good thing is the colored ones go to the diode board. so look for those colors to the diode boards. then from the diode board to A1J6. Hope this directs you to where the wires go.
#59 2 years ago
Quoted from Bax1:
Thanks for words of encouragement. So found the wires on the DIODE that matched and they all have continuity. So the loss appears to be from the DIODE board to the MPU (Control Board). Is that correct thinking. If so, the next question is what wire to trace. Is it the 433? Only thing is I know top right Bumper works. This is where I am confused. Thanks again for all your help.
#60 2 years ago
It probably isn’t that wire. I’ll need to look more in the schematics to see. Stay tuned. Might not be till morning.
#61 2 years ago
Might want to check those diodes. You will need to unsolder one side to test. That only thing I can think of.
Calling ChrisHibler
#62 2 years ago
Calling chrishibler
New problem out of nowhere. Start button not working and game won’t start. Test mode shows all switches open and none will register now. I made no modifications today and it was all working except the Three switches this morning. These things sure can drain you.
#63 2 years ago
And none of them register now. All switches non responsive
#64 2 years ago
This has to be the cpu. Where did you get the new board from? Does the swemmer board have a diagnostic in it?
#65 2 years ago
Do you have 5v going to the board?
#66 2 years ago
Quoted from Bax1:
I have a new power supply board. Not sure where to look for diagnostics on the board.
#67 2 years ago
did you check the voltage when you put the new one in? you always need to dial them in. should be 5.1-5.0v from the power supply then make sure the mpu is getting a solid 5v
#68 2 years ago
Going to see if these guys might be able to help. They helped me out a ton with mine
Quench
ChrisHibler
#69 2 years ago
False alarm. I had unplugged a connector and in my craziness had not connected it back. So back to just those three switches not working. Getting there.
#70 2 years ago
you fixed another problem been there before lol. so i still think you need to check those diodes. either use a flash light while looking at them or pull one side from the board and then test. they can be tricky to see if they've blown
#71 2 years ago
Quoted from Bax1:
Ok I will take a closer look. They are tiny. Thanks
#72 2 years ago
Quoted from Bax1:
I took a pic. As a rookie not sure what I’m looking for.
#73 2 years ago
To me, they look good. I hope these other guys can comment. I’m stuck
#74 2 years ago
Okay guys...brief me up. Too long of a thread to pour over.
Chris Hibler - CARGPB #31
Http://chrishiblerpinball.com/contact
http://www.PinWiki.com/ - The new place for pinball repair info
#75 2 years ago
Thanks for coming in Chris. Thing that I’m stumped on helping out with is he has 4 switches out 31,33,34,& 35. Had him do continuity from switch to diode board and it’s good. I’m not sure where to direct him to check next
#76 2 years ago
Also working with a swemmer cpu and a rotten dog driver board
#77 2 years ago
Thanks for joining in. BAX summed it up. The switches do not register during the test either. The kickout hole coil does fire during test, so it is just the switch itself it appears.
#78 2 years ago
And the other switches on that row do register, right?
Just a comment, physical switch connections will almost never match the order of switches as shown in the schematic. Switch matrix (and other) wiring is routed to minimize wire required.
Some switches in a row working but others in that same row not working rules out the MPU board and the connection to the board, assuming all switches come in at the same connector (i.e. all on PF or in cabinet.
This leaves only a few possibilities in this approximate order of probability.
1. Broken daisy chain between switches. Buzz from switch solder tab to all others in the daisy chain.
2. Failed switch. Clean the gold flashed contacts but pinching a business card between them and pulling it through. Meter for continuity when closed.
3. Failed 1N270 germanium diode or solder joint on the diode board. Remove the connector. Examine solder joints. Diode year with a meter. Should be open one way and about .220 the other way IIRC.
4. Failed IDC connection at diode board.
Multiple switch failures are almost always a break in the daisy chain.
Happy hunting soldier!
#79 2 years ago
ChrisHibler and Bax1 I am a first timer trying to restore my first machine. So I apologize I do not know all the lingo. Can you help me out on the following:
1. Buzz from switch solder tab to all others in the daisy chain. - What is this process?
The rest I understood. I am assuming no way to test DIODE by just looking huh?
Also, the daisy chain side of the switch is for the power? Can I attach them to any other switch as long as the oher line is going to the correct circuit/board?
Thanks again for helping me out.
#80 2 years ago
Test the continuity between these switches with on the same colored wires. so from 33 to 35, then 35 to etc..
to test the diodes, put your meter on diode test. one way you will get open or the sound from meter. other way you will get the reading that is stated above.
you got this!!!
#81 2 years ago
Any update muggy?
#82 2 years ago
Quoted from Bax1:
Any update muggy?
Still not resolved. Diodes are good, board good. What I thought was the daisy chain changes color somewhere I cannot trace to test. My guess is the schematic May not be totally accurate. Is there a way to power the switches for a test ? So close to getting this thing finished.
Have an awesome weekend
#83 2 years ago
so you have the button on the left inside the coin door to get into test mode. you keep hitting it till you get to switch test. it will then run through all the switches that are registering closed.
#84 2 years ago
Quoted from Bax1:
Thanks. What I meant, is there another way to get power to these switches? If the continuity is good to the diodes and board, I assume the power is not getting to the switches somehow. That is the Daisy chain? Just trying to find ways to get this to work.
#85 2 years ago
the daisy chain is the ground. each switch should have a separate color for power. (I think) you could test the switch continuity. have a probe on each end of the tab and then activate the switch to see if it has continuity.
#86 2 years ago
Quoted from Bax1:
So the power goes from diode to switch? Or is it the other way around? I don't get the row concept. I thought they all were powered together. So just grounded together?
#87 2 years ago
http://www.ChrisHiblerPinball.com/Contact ... for board repairs
#88 2 years ago
Thank you for the explanation Chris. My MC just started going crazy again this weekend. I have to do some digging on mine.
#89 2 years ago
Quoted from ChrisHibler:
#90 2 years ago
how are you coming along on this muggy?
#91 2 years ago
Quoted from Bax1:
So I have a fully functional Monte Carlo now! Two Diodes were bad. However, the problem was found to be the left drop bank was shorting out the switches. This caused one of my switch matrix chips to blow on my new board. However, it is good to go now. My guess is the wiring issues I spoke of before from the previous owner did this. But it is fixed now. Took me a while but thanks to you guys for all your help! Moving it downstairs to the game room tonight! Did you get yours fixed?
#92 2 years ago
Awesome!!! good job!!!! Now play the crap out of it!!!
yeah mine is good now. I had a broken trace, fixed but then went wonky again. I still may buy your old boards.
#93 2 years ago
Quoted from Bax1:
Oh no! Hopefully it will get repaired easily for you. I actually traded my boards for some repair help from a local tech I found. Sorry. And yes, we have a family tournament planned for tonight! I also think I convinced my wife to get another project pin I want one I played in college all the time: The Simpsons
#94 2 years ago
awe dang. I knew I should have jumped on them. It's fixed and should be more stable now. Have fun with the tournament. Just remember, the multi ball can be stolen during multi player games. kinda makes it fun that way.
Men
$ 5.95
The Pinball Scientist
Protection
$ 83.00
PinballReplacementParts
Gweem's Mods
Sound/Speakers
Other
1,500
Marshville, NC
This page was printed from https://pinside.com/pinball/forum/topic/monte-carlo-system-80b-gi-issues/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
