(Topic ID: 289047)
Monte Carlo system 80B
By oldskooler
2 years ago
  • 4 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by Bax1
#1 2 years ago
Hello everyone
After doing the ground mods on the interboard connector, and the ground mods on the transformer, the machine works.. but weird
I have a voltmeter, but no logic probe. Which I'll need on this game
Anyway, bought new boards (MPU and Driver) from ks arcade.
Machine boots, all 4 drop targets reset. Start a game, and I drop a ball into one of the three playfield kickout holes. It's not lit, so it should kick it out.
No, it stays put. Bonus collects, 2nd ball drops out to be plunged.
Then the weird stuff starts. First ball ejected, roulette wheel spins, bonus collected before roulette ball has landed. Then each of the kickout holes cycles in turn, then the ball return solenoid (very bottom) fires. And this continues until you switch it off.
Switch it back on. Game is set on 50c play. Drop in 2 quarters, nothing for first quarter, 4 games for the second.
Also,the boot sequence has changed. Each of the 3 kickout holes cycle in turn, THEN the drop targets fire one by one, then the game goes to attract mode.
Starting a game.. each kickout hole fires one by one, no sounds.
Pulling out what little hair I have. I'll end up replacing every component and board in this machine.
Perplexed, and thanks
Jaime
#2 2 years ago
honestly, it sounds like switches needing to be adjusted. I have a monte and will try to help as much as I can. having aftermarket boards will mess me up a little bit. I went through a few issues with the original boards.
#3 2 years ago
So.. the first things I started to look at, was the self test. Switches 15, 25, 35, 45, 55, 65, and 75 where on.
So looking at the switch matrix, which leaves and returns onto the main cpu.. the only wire common to all "5" switches is 655 (blue/green/green??). This must be going high or locked on, after a while.
It can't be the roulette wheel, as I've just repaired and confirmed that. There is diode protection for the wheel, just wondering exactly that is. On the strobe lines 400 and 411
Anyway..replaced Z13 (7400), and everything came back on, like nothing had happened.
I've already replaced Z14 as well.
Maybe start checking the remote diode boards (A7)
And then lastly.. start talking everything that can be unplugged off the board. System 80B is a law unto itself
#4 2 years ago
If these boards are new. Why do you have to change these chips? Is it a swemmer board?
Other
1,500
Marshville, NC
$ 5.95
The Pinball Scientist
Protection
Gweem's Mods
Sound/Speakers
$ 83.00
PinballReplacementParts
Men
This page was printed from https://pinside.com/pinball/forum/topic/monte-carlo-system-80b and we tried optimising it for printing. Some page elements may have been deliberately hidden.
