(Topic ID: 222461)
Monster Bash Remake (MBr) Owners Club (with Poll & Pics)
By MrSanRamon
5 years ago
  • 9,339 posts
  • 734 Pinsiders participating
  • Latest reply 4 days ago by Bikerjoy
  • Topic is favorited by 280 Pinsiders
Topic poll
“Monster Bash Remake (MBr) Owners Club (with Poll & Pics)”
  • I'm in on a CE 77 votes
    9%
  • I'm in on a SE 172 votes
    21%
  • I'm in on a LE 396 votes
    48%
  • I'm out for now 182 votes
    22%
(827 votes)
There are 9,339 posts in this topic. You are on page 187 of 187.
#9301 3 months ago
Hi, does anyone know if there was a mod pyramid for the back left of the playfield, have seen a couple on the internet but no description or who might have sold them, thanks
#9302 88 days ago
Me when I talk about Monster Bash with others:
#9303 88 days ago
Quoted from Pinballers:
Here is one on ebay ebay.com link: itm
Here is someone's site about a ton of mods they did to their game. Can't vouch for any of it though.
https://bandera6.wixsite.com/pinballmoding/mb-mod-directory
#9304 87 days ago
Quoted from SiN13:
What year is that advertisement?
#9305 87 days ago
Quoted from JBtheAVguy:
1991-1993 somewhere in there. Was a cross promotion with Universal Studios.
#9306 78 days ago
We are gauging interest in MMR RGB kits and XL Display kits. XL display kits will be available for all models with the small display. feel free to email [email protected] to get on a list. We are ordering parts now and since these have not been offered in quite some time, we want to make sure all who want them can get them.
#9307 78 days ago
Quoted from Thorn-in-pinball:
This sounds promising that the next MMr run is moving forward. Nice!
#9308 78 days ago
Very cool! I have a SE so I’m good. But that’s great news!
#9309 78 days ago
Don't think this is them saying they are running full games (even though it would make senses to do so along with kits).
#9310 78 days ago
I'm interested, I have a CE with the 13 and 7/8 inch display and the HD color upgrade. I'd like a little more info on this. What is the price and what is included? I'm assuming the 19 and 1/4 inch display and the frame to accommodate it. Does it included the SE/LE speakers with LED lighting?
#9311 77 days ago
Quoted from SiN13:
I got this correction from Jim.
"CCR is only the large display.
These would be for MB, AFM and MM.
The speakers would be upgraded in this kit as well. New speakers in the speaker panel and a new 8 ohm center speaker too!"
Thank you,
#9312 77 days ago
Quoted from LTG:
Thank you,
Any mention of price? I'm guessing this is the "0711-XLCD - XL Display & Premium Enhanced Sound System Upgrade Kit" item listed on their site which was once priced at $649.99.
#9313 77 days ago
Quoted from SiN13:
No idea from me. I don't know if CGC knows yet.
#9314 76 days ago
My right orbit is not activating/advancing the Wolfman. However, when I go into test mode and test the switch below, it seems to be working. I don't understand the mechanism for advancing Wolfman, but assume it is triggered by this switch. This problem may have started when the swinging wire at the base of the R orbit came loose (not sure). Any ideas? Thanks
#9315 75 days ago
Might be a long shot, but one thing to check is the plunger lane switch - if that triggers or maybe if it's stuck, the game ignores the right orbit for a short time, since it assumes a ball hitting that came up from the plunger.
Also, you mean to advance Wolfman before the mode is started, right? Once the mode starts, an orbit shot (either one) must go all the way around to count (except for the fourth one that ends the mode.)
#9316 72 days ago
Quoted from vikingerik:
Thanks for your suggestion. Turned out that when the wire came loose on the switch below, I didn't put it back together properly. The metal arm that is supposed to be above the wire had fallen below. This shows correct reposition.
#9317 71 days ago
Quoted from DazedandConfused:
So I guess that must mean that the 2 switches in sequence are what validate that a Wolfman shot was made.
#9318 71 days ago
Quoted from SiN13:
Yeah, I think so.
#9319 71 days ago
Quoted from SiN13:
This would explain the behavior I see in my OG Monster Bash. When I hit that right orbit, the Wolfman sometimes doesn't register, and I am fairly sure it is because the next switch in the loop doesn't quite trigger as reliably when the ball comes from the right.
#9320 62 days ago
Ran into a snag today on my MBr SE. I was cleaning it and decided I'd finally look at an issue I'd been having with the lowest LED on Swampy ("Muck") which was always dimmer than the rest. Lifted the playfield, reseated the connection, and powered back up. Now I've got solenoids not firing - literally none in the test except the left and right gates are working.
First checked F103 - swapped with the left flipper fuse, which is the same, and left flipper works but solenoids don't. Also pulled and tested the fuse, tests good. Checked all LEDs. Noticed two things - first, the LED CR107, which is indicative of F107, is dimmer than the rest. Didn't know if that was an issue or not, so I replaced F107, no luck.
Also noticed that CR105 on the solenoid power board was not lit when running. That LED is labeled as "CODE" and is supposed to be flashing on boot (it does this) and normally on. Anyone else confirm that CR105 is on? And what does "CODE" mean?
I did a full investigation of wiring under the playfield but since it's affecting all the solenoids, I am confused as to what it could be.
Thanks for any thoughts!
#9321 62 days ago
Quoted from macchiato:
Fixed. Pulled out the high voltage button and was able to play. Pressed back in and somehow it kept working. Switch might have been in an odd state. Thanks to Lloyd for the help.
#9322 62 days ago
Try playing a game with coin door open and high power interlock switch pulled out.
If that doesn't do it. Turn the game off. Reseat cable between playfield board and board in the head. Be sure all the connectors to boards in the head are on tight.
#9323 62 days ago
Chalk another fix up for @ltg. This community wouldn't be the same without you. Cheers!
#9324 58 days ago
Has anyone replaced the speakers in their MBr SE or LE? The Pyle’s from the factory are exactly that. When I got mine (with over 10,000 plays) one of the speakers crackled heavily, the other slightly. I bought another pair of the same and out of the box one of them already crackles. Looking to see if anyone has found a nice alternative. Would 25W/75W speakers be sufficient? Most of the more reputable brands tend to be rated that way for 2-way 3.5” drivers.
#9325 55 days ago
New to the club with an LE.
Is there supposed to be a ball save at the beginning of each ball?
#9326 55 days ago
Quoted from WizardsCastle:
By default no. I turned on a couple seconds of it for those once in a while early ball drains.
#9327 54 days ago
Quoted from SiN13:
I have the ball save time maxed out, which I think is 30 seconds, but it does not ball-save on Ball 5, I assume that is something set in the programming. Most people are probably playing three-ball games, so not an issue. At my skill level, 5 balls is good.
#9328 38 days ago
Quoted from mostater:
Please be true... I've been looking forward to getting one for some time. Thorn-in-pinball If you acknowledge this post, I'll take it as a sign.
#9329 37 days ago
Quoted from FullTilt83:
I asked some CGC guys at TPF last month, and they confirmed that another run of MMr would be done "near the end of this year". I did say to them that this is what they've told me during the previous two TPFs and they said "but this time we mean it...".
Take that for what it is worth...
#9330 36 days ago
I play my WOZ at 5 balls but my advice is dial it back to 3 balls for MB. The code is fun but not very deep. You will see it all WAY too fast IMO. No way you will ever see the end of JJP like WOZ.
#9331 33 days ago
Easy question: is there a setting for "family friendly" callouts? I'd like to avoid the "monstrous organ" callouts when the kids play. (Honestly, I think it'd go right over their heads, but I'm trying to avoid dirty looks from the parents) I looked in the manual but couldn't find a setting. Thanks!
#9332 33 days ago
Quoted from KingMixer:
Disregard, I found it. A.2 19.
#9333 14 days ago
Any further word on this?
#9334 6 days ago
Can anyone tell me how to remove the entire bride assembly? I got the head off, but can't seem to unscrew the rod on the coil. I can't see anything that's causing it to be stuck/catch on.
#9335 6 days ago
Quoted from Bluthgg:
Page 2-21 in the manual. It screws into the top of the plunger.
Probably have to hold the plunger and then unscrew it.
#9336 6 days ago
Quoted from LTG:
Thanks LTG, eventually got it unscrewed, the lock washer was a bit jammed and there was a lot of gunk in the threads. Recommended to grease it when putting it all back together?
#9337 6 days ago
I wouldn't.
#9338 6 days ago
Quoted from LTG:
I wouldn't.
Thanks LTG. This mech is....what a giant pain in the ass. Doesn't move smooth after reassembling. Think part of the plunger threads are a bit damaged so going to get another one and re-try next week. Everything else going well with the full shop/fix but I want to throw the machine out the window if I have to mess with that rod ever again
#9339 4 days ago
Joined the club this weekend with a very nice condition LE with < 2500 plays on it.
IMG_4197 (resized).jpgIMG_4197 (resized).jpgIMG_4198 (resized).jpgIMG_4198 (resized).jpg
$ 399.00
$ 40.00
The Flipper Room
$ 33.50
$ 24.75
The MOD Couple
12,400
Loris, SC
Precision Pinball prod.
$ 12.95
$ 69.99
Inscribed Solutions
Pinball Photos LLC
$ 24.99
Playfield - Plastics
Pinhead mods
£ 55.00
Sillyoldelf Mods
Filament Printing
$ 29.00
Pinball Photos LLC
$ 8.00
Pinball Fuzz
$ 5.00
Pinball Fuzz
$ 129.95
Hookedonpinball.com
€ 99.00
Lighting - Under Cabinet
Watssapen shop
9,500
Saint John, NB
9,000
Shepherdsville, KY
YouBentMyWookie
€ 99.00
Watssapen shop
Asheville, NC
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/monster-bash-remake-mbr-owners-club/page/187 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
