(Topic ID: 222461)
Monster Bash Remake (MBr) Owners Club (with Poll & Pics)
By MrSanRamon
5 years ago
  • 9,332 posts
  • 732 Pinsiders participating
  • Latest reply 3 days ago by KingMixer
  • Topic is favorited by 277 Pinsiders
Topic poll
“Monster Bash Remake (MBr) Owners Club (with Poll & Pics)”
  • I'm in on a CE 77 votes
    9%
  • I'm in on a SE 172 votes
    21%
  • I'm in on a LE 396 votes
    48%
  • I'm out for now 182 votes
    22%
(827 votes)
There are 9,332 posts in this topic. You are on page 150 of 187.
#7451 3 years ago
Quoted from SaltyRunBack:
I have an LE on the way and I really like the attached classic Williams logo instead of the CGC logo. Where can I find one of these? Thanks
you can try this one, looks fine on mine: https://www.dropbox.com/s/g8gkx7y2s712h9i/userlogo.bmp?dl=0
it's already in the correct size, looks blurry when zoomed in, but works well on the game itself.
#7452 3 years ago
Quoted from Eduardolicious:
ok followup dumb question...how the hell does this led come out of this spotlight??? lol
the spotlight is switched on only if Frank's table is up, spotting to standing Frank - also during lamp tests, the table needs to be up.
#7453 3 years ago
Quoted from gigo:
yep, its looking like a bulb with mine. was working with Chicago's support simultaneously to this, testing continuity etc, and learned from them that that light doesnt actually flash during any of the lamp/flasher tests, it only comes on during the frank table test. well i mean, mine doesnt, but yknow lol
also if anyone was curious the time/date problem was caused by the battery holder being full of some sort of sticky/paper residue??? no idea why it was in there and it was a pain in the ass to clean out, but it keeps time now
now if i could just come up with a cheap solution for the glare from the backbox ill be content. even at the lowest backbox brightness setting its just super glarey, ionno if im being picky or if anyone else feels the same way
#7454 3 years ago
In regards to SDTM problems:
A long while ago, I had planned on fabricating some adjustable spacers so that the ball would be resting on the plunger while in the scoop, as the plunger sits about 1/4" lower than the ball, and off center- resulting in random kickouts.
If the spring washer and/or other methods don't work, I definitely recommend doing this. The spring washer did the trick for me until the code update, and then I started getting SDTM drains again. The obvious underlying problem is that for whatever reason (flashers etc), the coil pulse power is inconsistent. This was addressed in the code update by allowing you to increase the pulse power, but it is still erratic, maybe even more so.....
With the erratic pulses, all you can do is try to control what you can- the spring washer helped to prevent coil movement, this fix will help prevent the chaos from the plunger hitting the ball off center, like a flubbed billiards shot lol. Anyhow-
After some quick measurements, there was really not enough space to fit in the adjusting nuts necessary for a stable jacking plate assembly, which is good, because this is even simpler.
All you need to do is:
a) Buy a package of "HEAVY DUTY ANTI-SKID PADS" from your local home depot, or order online. SKU is 101-032 (You'll also need a #12 3/4" machine screw and nylon nut, as well as a piece of 3/16"-3/32" heat-shrink tubing)
20201027_205957 (resized).jpg20201027_205957 (resized).jpg20201027_210848 (resized).jpg20201027_210848 (resized).jpg
#7455 3 years ago
b) Slightly bore out the pad with a 7/32" drill bit
c) Put a #12x3/4 machine screw through it.
d) Put a piece of heat-shrink tubing over threads, then cut about an 1/8"-3/16" away from rubber pad.
e) Remove the rubber grommet at bottom of assembly.
f) Place pad with machine screw through home where rubber grommet used to be.
g) Tighten nylon nut using an offset #2 screwdriver and 7/16" nut driver.
This pad is rubber, and the perfect height once installed, so that the ball is resting on plunger when in scoop. I used #12 bolt size and heat-shrink tutubing so that it would perfectly fill existing hole in bottom of assembly bracket with zero chance of it wiggling around and wallowing out the hole. If you don't have a drill and the necessary drill bit, you could install this using a #10x3/4 machine screw/nylon nut.
20201027_210826 (resized).jpg20201027_210826 (resized).jpg20201029_234110 (resized).jpg20201029_234110 (resized).jpgScreenshot_20201029-233717 (resized).jpgScreenshot_20201029-233717 (resized).jpg
#7456 3 years ago
Pics installed.....?
#7457 3 years ago
Lol sorry about that, it's there now.
#7458 3 years ago
Looks like the one I made. shoot me a PM if the website is down.
http://videopenny.com/images/userlogo.bmp
#7459 3 years ago
Is 1.0.3 the latest software?
Thanks - Brad
#7460 3 years ago
Yes.
#7461 3 years ago
Quoted from LTG:
Yes.
Thanks Lloyd!
#7462 3 years ago
Pop Bumpers Help: My pop bumpers, 50% of the time, can function completely normally and really get the ball moving. The other 50%, for instance, the ball can roll through the left lane, roll of the left bumper and then roll off the bottom bumper and never trigger the bumpers. I have attempted adjusting the bumper spoons under the playfield. They are near impossible to see. So, by trial and error, I have tried multiple different positions, but nothing helps. The distance between the switch blades looks good.
This can not be normal, correct? Am I missing something else that could be adjusted?
#7463 3 years ago
Quoted from SkaterVet:
You have to adjust the leaf/spoon switches. As hard as it might be to access, that’s where your issue lies. You can put the game in switch test mode and roll a ball around the bumpers to see if they are triggering. If not, keep adjusting.
#7464 3 years ago
I did this on bottom bumper, got 50 percent, improvement. I did some trial and error doing a ball kaunch to numbers to test .
#7465 3 years ago
I started getting this buzzing noise which I thought was one of the speakers on my LE. I lowered the volume to zero and still got it. I have a feeling it’s something in the translite or something similar in the backbox movement causing this. Anyone experience this on the remakes?
#7466 3 years ago
Pop Bumpers Help:
Turn the game off. Adjust the leaf blade switch for it below the playfield.
Turn the game off. Lift playfield up and lean back. See the leaf blade switch ? The long one with the plastic spoon is pushed by a plastic rod coming down from the pop bumper skirt. This plastic spoon should be clean, ( not worn on older games ) well centered on the rod, just resting on it, not pushing it up. The shorter lower leaf blade switch should be close enough so the slightest ball hit triggers it yet vibration doesn't set it off. A little adjusting/tweaking, and you'll be fine.
#7467 3 years ago
Mine works the exact same way, maybe 50% when the ball strikes the pop bumpers they actually fire off. My machine is brand new, definitely makes it annoying when trying to get to mummy mayhem.
#7468 3 years ago
Quoted from PinballGalore:
Yes. I did on afm classic. change the brightness on the translight. It will fix the problem
#7469 3 years ago
Quoted from LTG:
Thanks LTG. It is near impossible to see where the left bumper rod rests on its spoon, but I am able to press down straight on each of the leaf blades and the corresponding rod does not move. I believe this means they are well centered. From what you mentioned, I do believe the spoons may be doing more than just resting on the rod. What would be the adjustment to lessen their contact?
#7470 3 years ago
Yes. Adjust down a tiny bit. May take a tweak or two to get it right.
#7471 3 years ago
Quoted from LTG:
Yes, how do you adjust down to create resting instead of firm contact between the rod and the spoon? Thanks again!
#7472 3 years ago
Bend the leaf blade with the spoon down a tiny bit, back towards the fiberboard spacers. Remove the bracket holding the leaf blades to get at it better, but harder this way and easier to screw up. Or a point bender. Me, I use my finger.
Clean them first just to be sure. A piece or paper between the leaf blades, gently hold them closed and pull the paper out.
#7473 3 years ago
Yes. Change the back box brightness and you should hear a difference. I’ve checked about this before and it has something to do with resonance or something like that. Either way, it was relayed that it is nothing to be concerned with.
#7474 3 years ago
Another newbie question... I've got a Theater of Magic as well as an MBr SE, and I've had them both for about a year, so I was told it's time to change the batteries. When I changed the batteries on TOM, not only did I lose all my high scores, but all my settings as well. Had to go through and reset my settings all over again.
Glad to see that CGC replaced the AA batteries with a button battery. So my question is... Should a button battery be replaced after a year, or does it have a longer life? And also, is there a way to replace the battery without losing all my high scores and settings? Thanks!
#7475 3 years ago
If you change the batteries with the power on, you'll keep your settings.
-1
#7476 3 years ago
Hmm, these new games don't have NVRAM?
#7477 3 years ago
Quoted from Zablon:
No ROMs, so no.
#7478 3 years ago
Quoted from KingMixer:
This for your first question...
Quoted from icust298:
I check the voltage of the battery when I install it. Should be 3.3 or higher. Based on my key fob batteries, once the battery reaches 3.0 volts or less, it’s time to change them. I use the same rule of thumb for my pin batteries.
Check them once a year. If 3.0 or less, replace them.
You can enter your pins on pinside in your collection. There you can enter the date of the battery installation under maintenance. After one year goes by, pinside will send you a reminder email to change them. I use the feature and like it.
#7479 3 years ago
Quoted from LukyDuck:
Thanks, everyone, for the info!
#7480 3 years ago
PXL_20201101_193712486.jpgPXL_20201101_193712486.jpgAnyone having issues updating to the latest code? I'm trying to update my CE to the 1.03 version and it keeps giving me an error. I've redownload the file twice and flashed the image three different times now with the same result. I just updated my mmr using the same process and it was seemless.
#7481 3 years ago
Wasn't 1.03 already in your game ?
#7482 3 years ago
Quoted from netman63129:
I opened a support ticket because shots into the scoop were draining 1/3 of the time making the game unplayable. They said to loosen the 4 scoop screws and turn counter-clockwise and set the power to Max. First, my scoop has zero play so that is not an option. Second, I did try the Max option and that does seem to help a little as the ball is definitely draining less, but it still happens. Still waiting on a better fix.
Stupid question. New MBLE owner. Where is the adjustment exactly to set the scoop coil for max power? I didn’t see it when going through and scoop shoots sdtm every time.
12489D91-8835-4088-A26A-16DC154F0DC4 (resized).png12489D91-8835-4088-A26A-16DC154F0DC4 (resized).png
#7483 3 years ago
You may need to update your software. I believe that the Scoop adjustment was added later (and may not be listed in the manual).
#7484 3 years ago
Quoted from mbeardsley:
Anyone know what the most recent code is? Mine says 1.06B on start up
#7485 3 years ago
Quoted from PinRush72:
1.0.3 is the latest on their site.
https://www.chicago-gaming.com/coinop/monster-bash/update
#7486 3 years ago
Yeah i'm running 1.03, no choices for scoop i can see. Maybe i'm missing something.
#7487 3 years ago
It is on the next page under Game Features Menu....
#7488 3 years ago
Quoted from mostater:
L eject strength ?
#7489 3 years ago
L eject strength ?
I believe it is the right popper coil. I think the left one is referring to the creature.
#7490 3 years ago
That's correct
#7491 3 years ago
Correct and from the patch notes:
Added setting to keep right popper coil activated longer to help avoid center drains from the popper.
#7492 3 years ago
Quoted from LTG:
I believe it was 1.01 but I'll have to double check now. Mine was one of the first CEs off the line and has never been updated.
#7493 3 years ago
Quoted from Oaken:
Adjusted, was going SDTM 100% now 50% but even if it doesn’t it barely hits left flipper. I ordered the washer recommended on this thread. Any other known fixes? Thanks for any help.
#7494 3 years ago
https://pinside.com/pinball/forum/topic/monster-bash-remake-mbr-owners-club/page/145#post-5800923
#7495 3 years ago
I confirmed it's version. 1.01 any tips on updating?
#7496 3 years ago
Quoted from Deez:
Follow the instructions on the website.
#7497 3 years ago
Quoted from Deez:
Their update is a pain. You need a micro sd card
#7498 3 years ago
Quoted from LTG:Follow the instructions on the website.
I did and it gives me this error.
#7499 3 years ago
Quoted from Deez:
Try to reach edwin at cgc. He will know what to do. I can't remember how I got thru updating, but harder than sterns
#7500 3 years ago
Are these still around with dealers?
Anyone know where I can find an LE nib?
9,400
Shepherdsville, KY
$ 12.95
€ 99.00
Lighting - Under Cabinet
Watssapen shop
Pinhead mods
€ 99.00
Watssapen shop
Pinball Photos LLC
$ 5.00
Pinball Fuzz
8,900
Pittsburgh, PA
$ 38.00
Various Novelties
Pinball Photos LLC
13,000
Loris, SC
$ 399.95
Pin Stadium Pinball Mods
$ 219.00
Lit Frames
YouBentMyWookie
$ 33.50
$ 24.75
The MOD Couple
$ 399.00
£ 55.00
Sillyoldelf Mods
Lafayette, LA
Filament Printing
$ 129.95
Hookedonpinball.com
$ 29.00
Pinball Photos LLC
$ 1.29
Daddio's 3D Printed Mods
$ 69.99
Inscribed Solutions
This page was printed from https://pinside.com/pinball/forum/topic/monster-bash-remake-mbr-owners-club/page/150 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
