(Topic ID: 222461)
Monster Bash Remake (MBr) Owners Club (with Poll & Pics)
By MrSanRamon
1 year ago
  • 6,215 posts
  • 483 Pinsiders participating
  • Latest reply 10 hours ago by Lounge
  • Topic is favorited by 195 Pinsiders
Topic poll
“Monster Bash Remake (MBr) Owners Club (with Poll & Pics)”
  • I'm in on a CE 40 votes
    7%
  • I'm in on a SE 101 votes
    17%
  • I'm in on a LE 306 votes
    50%
  • I'm out for now 161 votes
    26%
(608 votes)
There have been 1,067 images uploaded to this topic. (View topic image gallery).
There are 6215 posts in this topic. You are on page 123 of 125.
#6101 31 days ago
Finally got around to replacing the factory protector with the Cliffy and Mantis combo. Fits pretty good. Now let’s see how long it lasts.
D0F45CA9-0928-4D51-BDF4-57E7B6EB0F0E (resized).jpegE895CFE9-8634-4D1E-ACF6-3F37449C1C2D (resized).jpegECFD018C-171D-4332-BAED-562D106B24BF (resized).jpeg
#6102 31 days ago
how long did it take you
Quoted from Plunger069:
how long did it take you?
#6103 31 days ago
Quoted from fanuminski:
An hour or so. I had to remove the big circuit board to install the Mantis. Took a lot of pictures of the connections on that board. The Cliffy seems to fit tighter to the playfield and allows the ball to roll in the scoop from the side a lot more. The direct shots to the scoop don’t get rejected quite as much either. So far it was worth the effort.
#6104 30 days ago
Thanks for posting this. I think I'm going to do the same to mine as the scoop rejections are driving me crazy!
#6105 29 days ago
My LE finally arrived a couple weeks ago and it was well worth the wait. I have had no time to do anything but clean the balls first, put them in and start playing. No problems have been found and the game plays smooth as butter.
Thanks to CGC for doing such a beautiful job of remaking this game, and for all the beautiful add ons that came with the LE.
#6106 29 days ago
Has anyone had a problem with your slingshots misfiring? My right slingshot is often firing when the ball is nowhere near it. Usually it happens upon another electrical event like using the flippers or the pop bumpers getting hit, but sometimes it just fires for the hell of it when the ball is plain old rolling down the middle.
Thought I found a bit of a loose connection for that slingshot underneath, reseated it, no dice, still misfires. Any ideas? I've seen some general advice about slingshots and the leaf springs (if that is the right term) inside the slingshot either being too close together or too far apart, but that doesn't seem to be my issue. I also have a bum plasma disc that never worked, so I really need to get in touch with Chicago Gaming. Until then, though, any suggestions are welcome.
#6107 29 days ago
Quoted from VALIS666:
Sounds like the sling switch is too tight. Just need to spread the contacts apart a hair. I bet the vibrations of the other events is making the contacts connect.
#6108 28 days ago
Turn game off. Check the rubber ring, slide it around the posts to be sure it isn't tight on one side.
Remove the plastic over the slingshot. Look down at both leaf blade switches. The long front blade should just be resting on the rubber ring not pushing it. The shorter rear one close enough so the slightest ball hit triggers it, yet vibration doesn't.
A little tweaking and you'll be a slingshot adjuster pro.
#6109 28 days ago
Quoted from Lounge:
Quoted from LTG:
Thanks Lounge, and LTG, you're a saint on these forums. Before asking here I gently bent the leaf blades apart with a needlenose and the flipper cover still on, it just made the issue worse somehow. Followed LTG's advice tonight and took the flipper cover off (unseen tiny washers ahoy!) which gave me better access to the shorter rear blade and also a more useful top-down angle, bent that rear blade back a bit and voila, no more chattery slingshot. Also took the rubber off and reseated it, which was a little twisted in the grooves, so it was probably sitting tighter than it should've been. Cheers guys.
#6110 25 days ago
Just joined the club with my SE. Love this game. Issue with Drac's feet, but already solved. Put in the trough lighting kit from Mezel Mods which is great!
#6111 25 days ago
Quoted from Roon:
Nice line up !
#6112 25 days ago
Quoted from Roon:
Just joined the club with my SE. Love this game. Issue with Drac's feet, but already solved. Put in the trough lighting kit from Mezel Mods which is great![quoted image]
Welcome to the club! Everyone loves it at my place. Not a single issue with it.
Now I just wish they would hurry up and announce their next machine. I am itching to buy another one and am having a hard time deciding on which one.
#6113 24 days ago
Well since my mbr has the latest version installed, I’ve been thinking about the other machines.
I have the original rom installed and would like to upgrade. Which version should I seek to purchase? How do I best figure out what the differences between them are and which one would work best? is replacing the chip easy? Just pulling out the old one and sticking this one instead? I always thought it would require removing the board and soldering the replacement on.
Lastly, what do the sound chips offer? Better quality sound? Added sounds not available originally?
#6114 24 days ago
Quoted from Roon:
What did you have to do with Dracs feet?
#6115 24 days ago
Quoted from mcfly:
Hi Mcfly, see post 6053 on this forum.
#6116 24 days ago
Has someone got a close up pic of the playfield showing a decent reflection on the clear coat? This is my first NIB so I have no reference point other than 30 year old B/W and a couple of restored games. But the playfield shows a very obvious texture to it which seems to transfer into the clearcoat. Almost like the wood texture (planking?) below. I have a, unpopulated CPR WW playfield and it's super smooth, whereas the MB isn't.
Running you finger left to right, you can feel texture, not so when running top to bottom.
I've added some pics, the close up showing the smooth inserts shows a good comparison. This “texture” is pretty consistent over the entire playfield.
3F03E6A2-162F-47EB-B0C9-E922F782B850 (resized).jpeg78B28571-3B57-437B-BEF5-8207872582D5 (resized).jpegBAAFC519-19E6-4CE8-8ED5-EA11C1C0ACB7 (resized).jpeg
#6117 24 days ago
Quoted from shokel328:
New machines don’t work the same as the old machines. No ROM swapping anymore. CGC updates are done via micro SD cards.
#6118 24 days ago
Quoted from Flynnyfalcon:
Wow.... have you contacted CGC?
#6119 24 days ago
Quoted from Lounge:
Should I?
#6121 24 days ago
Mine looks like glass....
#6122 24 days ago
#6123 24 days ago
As mentioned I haven’t thought anything of it until today when I took a close look some CPR and Mirco playfields
#6124 24 days ago
Can’t really see the clearcoat reflection from that angle lounge
#6125 24 days ago
I’m away from home right now. I’ll repost better pics in a few days.
#6126 23 days ago
Quoted from Lounge:
Thanks lounge.
as mentioned I have the latest update on my mbr - and did it all myself with the msd card. Very simple.
1) I was asking what needs to happen on those older machines I have.
Twilight,flintstones,wh2o and monopoly.
All those games could do with an update as they are all the same code that left the factory 25 years ago. I’m considering replacing the rom/version - and I’m trying to understand if that’s a simple, no solder, take out old chip stick in new one...
2) I’d also like to know where I can figure out which rom is the smoothest running, good for home use etc - so where can that info be obtained. Each game would have different rooms to choose from.
3) My last question was to better understand what replacing a sound rom would do to a game. Is it something to consider?
Thnx
#6127 23 days ago
Thanks lounge.
Thnx
The old ROMs are a socket. Pull the ROM out with special pliers (or very carefully with a flathead screwdriver) and push the new one in. Where to get them... no idea.
#6128 23 days ago
Thanks lounge.
Thnx
Read about each game on ipdb.org, and you will find the latest version numbers listed. You can even download the actual ROM, and if you have an EEPROM burner you can make them yourself! Or buy from one of the many retailers who sell these.
TZ latest is 9.4H. -DO NOT- buy the 9.4CH, they are different and 9.4CH was made as a hacked version, and stopped Ted Estes from ever putting out further TZ updates.
Not sure on WW, a lot of games never get upgraded, you should verify you have the latest.
To install you just carefully remove the ROM chip (it is not soldered), and carefully reinstall the new one. Don’t Bend the legs!
#6129 23 days ago
Quoted from Rdoyle1978:
That’s exactly the info I was Looking for.
Cheers mate
#6130 23 days ago
Oh and what would replacing the sound rom give ?
#6131 23 days ago
Depending on the game. An updated version may add more sounds or cure problems. Like the occasional screech on Attack From Mars or Safecracker.
#6132 23 days ago
Quoted from Roon:
From wich shop you ordered MB?
#6133 23 days ago
I think it depends on the game, but many games use the same Sound ROMs even when you upgrade the main game ROM, so there's nothing to upgrade. You have to look on IPDB
#6134 23 days ago
How has your experience with CGC tech support been? I'm close to a week now with no response on a support ticket (plasma disc behind the Bride never worked once on my LE). I realize they're much smaller than JJP and especially Stern, but those guys get back to me usually within 24 hrs. Just keep holding on, or is there a better way to get a hold of them rather than support tickets? (ticket #4604 if anyone from CGC is reading)
#6135 23 days ago
Your ticket is overdue. I alerted it to Edwin. You should hear from him when he is back in on Monday.
#6136 23 days ago
That is what is referred to as a “Ribbed Playfield” that sucks my friend.
#6137 23 days ago
Quoted from whthrs166:
And that’s a manufacturing issue and should be fixed? Just wondering where I stand.
#6138 23 days ago
Quoted from LTG:
You're the best, thank you.
#6139 23 days ago
Yes it should. I would contact CGC on what they have in mind.
#6140 23 days ago
ltg any thoughts?
Ticket submitted to CGC and email sent to local distributer. Discovered a local buyer of a MB remake had a similar issue, CGC replaced it with an entire populated playfield. Hoping for a similar solution.
#6141 23 days ago
Any idea on how to dim the 4 or 5 bright LED's near the shooter lane? I dimmed them in settings but they're still obnoxious...can these be replaced with incandescents?
#6142 23 days ago
any thoughts?
Ticket is the way to go.
No idea what they will do. I have no say in that.
#6143 23 days ago
Quoted from CubeSnake:
No.
#6144 23 days ago
Your ticket wasn't alerted to anybody. I alerted it to Edwin. He's at CGC, he'll see it goes to who it needs to.
#6145 23 days ago
Quoted from LTG:
Thanks mate.
#6146 21 days ago
Quoted from LTG:
Hey ltg, I kinda ballsed up and accidentally closed my ticket . Is there any chance you can pass on the message to Edwin to reinstate it, or bump up my new ticket. 2-3 days of waiting for a reply for nothing
Old ticket was 4626, new ticket 4636
Big thanks!!
#6147 20 days ago
It didn't look like I could reopen the one you closed. Your new one is alerted to Ryan, and I put a note on there about the first one.
Thank you.
#6148 20 days ago
Quoted from LTG:
Thank you.
You’re a good man Thanks.
#6149 19 days ago
Hi,
I am new here. I just ordered the Mbr LE and he will be delivered by the end of next week.
I ordered my MB in Germany, but I live in Belgium (there is no dealer in my country). I can change the language from German to English in the menu, but what does the dip switches do?
Do I change the language in the menu or do I change the dip switches from german to european?
Thanks for the help,
Niels
#6150 19 days ago
Quoted from NielsVV:
You can set the switches in the CGC menu.
$ 225.00
Cabinet - (Alt) Translites
FlyLand Designs
