(Topic ID: 222461)
Monster Bash Remake (MBr) Owners Club (with Poll & Pics)
By MrSanRamon
2 years ago
  • 7,165 posts
  • 552 Pinsiders participating
  • Latest reply 1 day ago by tracelifter
  • Topic is favorited by 229 Pinsiders
Topic poll
“Monster Bash Remake (MBr) Owners Club (with Poll & Pics)”
  • I'm in on a CE 52 votes
    8%
  • I'm in on a SE 127 votes
    18%
  • I'm in on a LE 340 votes
    49%
  • I'm out for now 169 votes
    25%
(688 votes)
There have been 1,192 images uploaded to this topic. (View topic image gallery).
There are 7165 posts in this topic. You are on page 122 of 144.
#6051 11 months ago
Quoted from skibum:
Just unpacked my LE, and I can't find the back box key. I searched this thread and saw where people said it should be on a hook on the coin door, but I didn't see a hook or keys. I searched the whole cabinet and the shipping stuff again just in case it fell out, but nada. I attached a pic of my coin door just in case I'm totally blind.
My coin box keys were both in the manual bag, nothing was in the coin returns. Couple of questions:
1) Any idea what Chicago does in this instance? Will they send another set of keys?
2) I was going to take the lock off <want to attach the bolts and run the sw update>, but the screws appear to be secure torx, which I don't have... can someone confirm the type and size screw? And, if I remove the screws, will that remove the lock, or would it still need to be drilled out?
Thanks[quoted image]
Just to update this for anyone that has the same problem, I opened a ticket with Chicago, they are sending replacement keys. I did search the entire cabinet but failed to find them. LTG drew on the pic I posted showing where you should be able to find them on the coin door, definitely check there first.
If you need to access the back box without keys, the screws around the lock are theft proof or security torx size 20. Once you remove the screws the lock comes out with the plate, and you can remove the backglass.
Thanks to LTG for the quick responses.
#6052 11 months ago
Quoted from indybru:
I was getting more than a fair share of SDTM from the right outline. When it came down that side it was always an adventure if it would drain or not.
My tech replaced the rubber post just above the Drack track with ones that were larger/wider. Problem has been solved.
He tried one set slightly wider it didn't help much but the second one did.
Could you post a pic of what you changed it to?
#6053 11 months ago
Quoted from Lounge:
The first picture is what I had and tried.
The second is was the tech's solution to right outline drains. He said the new rubber post was from Data East part. Good luck
#6054 11 months ago
The second is was the tech's solution to right outline drains. He said the new rubber post was from Data East part. Good luck[quoted image][quoted image]
So what this is doing is pushing out the ball guide, similar to what has been discussed before, but it is a better option than just bending the part out because it's supported by the post rubber. Nice
#6055 11 months ago
Finally got it yesterday. I’m in love!
#6056 11 months ago
Which knocker should be purchased now that the software upgrade allows for one? Since it’s not in the original game either I guessing a reference number isn’t available for mb specifically, does anyone have a link or description?
#6057 11 months ago
Quoted from shokel328:
This kit has everything - https://www.marcospecialties.com/pinball-parts/B-10686-1
#6058 11 months ago
Don't forget to clip the diode on that spooky coil.
#6059 11 months ago
Quoted from Kneissl:
Thank you !
#6060 11 months ago
I edited a better solution.
Thank you.
#6061 11 months ago
Quoted from LTG:
Thank you.
But.. The spooky kit has a compatible wire harness and cool ghost on the coil; fits the theme!
#6062 11 months ago
Understood. But like you pointed out, people have to remove the diode.
I know some people won't know or forget.
#6063 11 months ago
Anyone know what the deal is with CGC's website? Every time I go to download the update for my MBr, the site is down... I suspect it could have to do with the fact that the download is 8 gigs and they just don't have the bandwidth for it.
#6064 11 months ago
Quoted from donjagra:
Try refreshing your browser. Then try it.
#6065 11 months ago
Quoted from LTG:
Nope, still F'd. I can post on pinside, can't get to any part of their website. It's happening on 4 networks I use, on 5 different computers and on three different mobile devices. I struggle to believe the problem is on my end.
#6066 11 months ago
Nope, still F'd. I can post on pinside, can't get to any part of their website.[quoted image]
Try a different browser? Working perfectly for me
#6067 11 months ago
Nope, not on explorer or firefox either. I have been waiting to update because I didn't have a card for it and it seems to only work once or twice a week. I wonder if the problem is with Comcast.
#6068 11 months ago
I can get to the site I Safari.
#6069 11 months ago
Xfinity is the problem. Thanks guys.
#6070 11 months ago
I downloaded it at 2:00 and had to redownload it at 4:00. It took me from 2:00 to 7:30 to get it on the card right. I was trying to unzip it with Windows unzipper but would not work. It wouldn't put it in a .img file. So I downloaded Breezip and it worked. It took me some time to figure Breezip out. Pain in the ASS to get it on the card right, but all is good now.
#6072 11 months ago
I fixed the right ramp ball stuck issue on my MBr. I took the ramp out and filed the V inner edges down. There were six small nubs. I also bent the ramp in slightly. No more ball stuck on ramp. I think this fix was posted before.
#6073 10 months ago
I updated the code to 1.03 3 days ago and now seem to be getting SDTM ejects from the scoop where I wasn't getting any before.
Anyone else? If I need to make a scoop settings change, does anyone know what the settings are to make it behave as it once did?
#6074 10 months ago
Fellow Pinsiders,
Proud owner of MBrLE #106. Phenomenal game love it to death.
Only small issue is the speakers are creating a buzzing sound from middle of playfield area, well i believe thats where its coming from. Definitely not the speaker itself. And if course the dracula feet issue small things that can be adjusted.
#6075 10 months ago
Quoted from CHIEF1893:
Fellow Pinsiders,
Only small issue is the speakers are creating a buzzing sound from middle of playfield area, well i believe thats where its coming from. Definitely not the speaker itself. And if course the dracula feet issue small things that can be adjusted.[quoted image]
I've noticed the same recently, let me know if you find a solution
#6076 10 months ago
Hi Guys
Same thing was happening to me ( if its the same thing ) and I couldn't work it out then I realized the little rattling sound is actually coming from the play-field glass probably being pushed/ slid to far up and it sits right under the two coloured speakers on the backbox which causes some slight rattling on the glass , just slide the glass a little bit down towards the lockdown bar and if its what I had , the rattling will stop and you should be all good the play this wonderful game again.
I must say my family and I absolutely love this game and the game is visually stunning - extremely happy with it , an absolutely beautiful machine !!
Cheers
#6077 10 months ago
In the days of pinball manufacturers not coming through. I am completely 100% satisfied with my MBr.
Can't wait for the next announcement from CGC! Maybe we will get something at expo?
#6078 10 months ago
Quoted from Halfwasted:
Ditto
#6079 10 months ago
You absolutely right! Took glass out and the buzzing went away! Thanks.
#6080 10 months ago
I joined the club a couple weeks ago with an SE. Love, love, love MBr! But...
One thing I noticed that is odd is that the pop bumpers are not easily triggered. Especially the one below the "D" lane. Sometimes it even gets stuck on that pop and I have to wait for a ball search. What do you think is going on here?
The left outlane seems really hungry! Is that just the nature of this MB or do I need to dial it in somehow?
Great to be here!
#6081 10 months ago
Quoted from konjurer:
Leaf blade switches that trigger them need to be more sensitive. So the slightest ball hit triggers them but vibration doesn't.
#6082 10 months ago
Quoted from LTG:
Come to think of it, mines the same. How would we make the blades more sensitive? Menu adjustment or a physical one to the actual switch?
#6083 10 months ago
An interesting occurrence..about 2 weeks back I updated the software. From the first game played after the update, my phantom flip would only light one side. If I hit the flipper button to switch it to the other inlane - it would stay unlit, and would not award me the auto-flip either. The side that would light worked as normal.
After a couple days/games I thought perhaps there was an operator adjustment for 1 or both phantom flip features to light, but never attended to this.
A few more day/games and the problem seemed to have solved itself. Everything is working as before the update and all’s good. Anyone else with the real ghost of the phantom living in their machine?
#6084 10 months ago
Phantom flip learns or teaches itself to operate. It takes several games for this to happen. The manual addresses this and also the tech dept. told me the same thing. Code update probably erased what was previously learned.
#6085 10 months ago
Quoted from Moeman65:
It's a *lot* more than "several" games too. You have to have the ball come down the inlane and roll onto the flipper, and make a shot (to the bride ramps, or the frank ramp usually), and *that* has to be done several times before the game will attempt it
#6086 10 months ago
Quoted from Rdoyle1978:
I know actually mine took probably close to 50 games, but rest assured it will start to function.
#6087 10 months ago
The learning curve is understood, that’s not the issue here. What happened was that one side of the feature was disabled altogether. Only one side would light up while the other was just completely disabled, so when you hit the flipper for the blue light to switch sides, because that’s the inlane the ball is going to, it would not light or register it as a phantom flip. Nothing to do with learning the shot. That’s why it was so odd. Never happened when I got the machine in June nib.
#6088 10 months ago
Not an owner yet but plan to add this amazing game next. How long does CGC usually make their games for? How long can I wait to still get this NIB usually? I'm looking to get the special edition. Thanks!
#6089 10 months ago
Ok now that does sound like a bug. You checked the LED in test as well?
#6090 10 months ago
I had the exact same issue. The next day it was working again. Never did figure it out. This was several months ago and it's never happened again.
#6091 10 months ago
Physical one to the actual switch.
Learn to adjust a leaf blade switch. It can take several tries to get it good. Top one needs to have the plastic rod coming down from the pop bumper skirt centered in the plastic spoon, and just resting on the plastic rod not pushing it. The leaf blade switch needs to be clean ( hold a piece of paper between the blades, gently push together, and pull it out ). The lower shorter one needs to be close enough so the slightest ball hit triggers it but vibration doesn't. A couple tweaks should do it. And I'd do this with the power off.
After a few times you too will be a pro.
#6092 10 months ago
Loving my new LE. What is the most current code? At startup it says 1.06B. Chicago Gaming website is unclear - looks like 1.03?
#6093 10 months ago
Quoted from mkk629:
~~ deleted ~~
#6094 10 months ago
Quoted from mkk629:
Look under where it says 1.06B, you will see CGC Version in very small letters. That is the update we are referring to. I don't think we will ever see the actual game code change.
#6095 10 months ago
Quoted from mkk629:
1.03 is the current game code.
Please go into the CGC menu ( page 1-10 in the manual or
the first page shows what is in your game.
Thank you,
Lloyd
#6096 10 months ago
Thank You. Both show 1.0.2 Guess I need to get a micro sd card and update
#6097 10 months ago
I never got to checking anything, a few days later it was all back to normal...
#6098 10 months ago
Quoted from LTG:
Well on my flintstones which I just received a few weeks back, the one jet wasn’t working at all, and I noticed one side of the rod was broken and the whole spring/yoke assembly was messed up. So I’ve managed to get it to work for now and the parts should arrive in a week or two. Guess I’m going to be a jet bumper pro soon. It’s about time after 15 years I started fixing my own machines thanks for the input!
#6099 10 months ago
Does anybody know how to install the rgb interactive trough light made by Mezelmods? Can't find it on their website. A link would be helpful
#6100 10 months ago
Sorry guys, my mistake. Wrong website, had to be Lermods...
$ 33.50
$ 100.00
The Flipper Room
