Quoted from gmagno:
Ball got stuck twice last night and when searching the Frank table went up and down both times. Please tell me more about the switch adjustment. It reads broken on testing but you are telling me its only an adjustment? Thanks in advance for the help.
gmano,
As always, everything Lloyd said is correct, but understand that the message you get during testing that the switch is broken simply means that the switch is not being fully engaged. A simple adjustment to (i.e., bending of) the correct switch should likely solve the problem. In this case. there are two long metal switches underneath the mechanism under the playfield that Lloyd references (they are under a square plate, but still mostly visible), and each one is engaged one at a time as Frank goes up or down. Bending the correct switch just a bit so that it's fully engaged as the Frank table moves may be the answer.
I may be able to help you with a video, but first, please describe clearly exactly what's happening during game play. I read your posts above but I can't tell even from those exactly the problem you're having currently. When the two Frank targets are down and you shoot the ball up the Frank ramp, what happens? Does he come down to a vertical position? After you've drained down to one ball during multiball, what happens? Does he go back up to the horizontal position?
