New! Dark mode!
(Topic ID: 222461)
Monster Bash Remake (MBr) Owners Club (with Poll & Pics)
By MrSanRamon
2 years ago
  • 7,330 posts
  • 566 Pinsiders participating
  • Latest reply 3 days ago by LTG
  • Topic is favorited by 236 Pinsiders
Topic poll
“Monster Bash Remake (MBr) Owners Club (with Poll & Pics)”
  • I'm in on a CE 55 votes
    8%
  • I'm in on a SE 136 votes
    19%
  • I'm in on a LE 351 votes
    49%
  • I'm out for now 169 votes
    24%
(711 votes)
There have been 1,219 images uploaded to this topic. (View topic image gallery).
There are 7330 posts in this topic. You are on page 115 of 147.
#5701 1 year ago
Quoted from Bublehead:
One other thing about the scoop SDTM’s, I found a mechanical solution that I have done along with the wavy washer and piece of foam inside the scoop. I literally locked the old visegrips on the top and gave the whole scoop a 1 to 2 degree twist to the left. This now aims really hot shots out of the scoop right at the pivot of the left flipper, no higher, and when it poots one out, like a misfire or soft eject, the ball gets to at least the meat of the tip of the left flipper, as in it will always rebound to the right flipper or rebound to be controllable. No more STDM or loss of control. CGC has told me they are looking at this issue when I talked with a rep about it, but I said since I have got mine tweeked, I have had no major issues since. I am getting to MOR regularly, my CG is 540M+, and so I consider mine as good as she gets right now.
The real issue appears to be with the strength of the eject - sometimes being only just enough to lift the ball out so that it simply rolls straight down. A proper fix should probably still be made, even if you have managed to divert the bad behavior temporarily.
I (LE) and my neighbor (also LE) are still awaiting a fix as well.
#5702 1 year ago
Joined the club over the weekend
CF6FE0C5-0068-4F46-A1FD-540CBC5C28C5 (resized).jpegAD36C5F4-BBC1-4E4F-A0C5-35E21D321A57 (resized).jpeg5ED24BC8-C762-4B53-A131-9FEE941971C6 (resized).jpeg
#5703 1 year ago
Quoted from neverahighscore:
A little Modfather Magic!
Love that paint job! Need to consider doing that to my CE version play field guys!
#5704 1 year ago
How do you all think this compares to ghost busters?. I was thinking of getting a gb pro or standard mb
#5705 1 year ago
Quoted from zaki:
I would take a MBr all day long before even considering Ghostbusters....it's annoying & repetitive as all hell...MBr at least has "substance".
#5706 1 year ago
MBR is a no brainer. Played GB again recently and still didn’t like it. I found it difficult and annoying. MBR on the other hand is very enjoyable for me. Play them both because you will get a wide variety of answers
#5707 1 year ago
Ugh. ANYTHING but Ghostbusters.
#5708 1 year ago
lermods plasma disk blue, green, or multicolor? I'm leaning blue but wish they did a better job showing a video of each.
#5709 1 year ago
Quoted from zaki:
Tough call, MBr is probably the best theme ever but gb is a whole lot deeper and a pro costs about $1500 less. Fun factor I would say they are even.
#5710 1 year ago
Quoted from elf70:
I think CGC is brutally aware of this and are more than likely working on it. I believe your observations are similar to mine, there is a electrical reason (such as a timing issue on the scoop firing pulse) that makes ejects from the scoop differ in strength at times. My fix turned the aim of the scoop more to the left so soft ejects still make it to the left flipper tip and are recoverable. Standard full strenghth ejects from the scoop hit the flipper bat at the shaft end 90%, but on a really strong eject it makes it to the left inlane guide, something you really don’t want it to do since it will eventually mushroom the stainless at that spot, and possibly nick your balls, which then they slowly destroy your playfield with little curly ball trails.
#5711 1 year ago
Quoted from Edster:
My Iron Maiden has tons of dimples. It looks like bad complexion. My older W/B games have next to none.
your older games might have been evened out...
#5712 1 year ago
In the club now since my MBR LE #726 arrived Monday June 17th just a week shy of waiting 8 months. Have had no issues after unboxing it and impressed with the quality.
#5713 1 year ago
Quoted from tdunbar:
Congrats!
I had mine for 4 months..Zero issues. I have yet to have to adjust anything, quality is amazing..Very impressed with CGC
#5714 1 year ago
Nearly 8 months after ordering, my MB LE finally arrived today and appears to be in pretty good shape with the exception of the fact that the ball gets stuck on the left ramp right after the switch. Does anyone know an easy fix for this? I haven't completely leveled the game yet but that is not going to help here as the ball definitely doesn't have enough space to clear the ramp unless I pull on the wireform a bit. I could probably pull on ramp enough to bend it slightly more open but I don't want to risk making something worse if that's the wrong move here so I figured i'd ask first.
#5715 1 year ago
Quoted from greenhorn1:
Nearly 8 months after ordering, my MB LE finally arrived today and appears to be in pretty good shape with the exception of the fact that the ball gets stuck on the left ramp right after the switch. Does anyone know an easy fix for this? I haven't completely leveled the game yet but that is not going to help here as the ball definitely doesn't have enough space to clear the ramp unless I pull on the wireform a bit. I could probably pull on ramp enough to bend it slightly more open but I don't want to risk making something worse if that's the wrong move here so I figured i'd ask first.[quoted image]
Wax it!
#5716 1 year ago
I'll try waxing first but the ball is really squeezed there. I have to use a tiny bit of pressure to even push it through.
#5717 1 year ago
I'd do that.
#5718 1 year ago
Quoted from BOBCADE:
Multi is awesome!
#5719 1 year ago
Quoted from shokel328:
I know the number, It's happening
Should be boarding A FLIGHT from Frankfurt to TLV next week.... Anyone else had theirs delivered to an airport ? Kind of cool...[quoted image]
Yes my alien came from Australia in a huge wooden crate by us airways. Not a fan of us airways but at least they got it here safe and sound . Airport, import fees , and broker fees were interesting
#5720 1 year ago
Quoted from Oneangrymo:
The holy grail has arrived in the holy land. This morning. I live about 20 minutes from the airport. so close...
Now comes the wait for customs clearance and all those other good things you mentioned :-p
Let's see how that goes, and how fast its gonna make it to its final destination.
#5721 1 year ago
Congratulations! I think you’ve been the most patient person here!
#5722 1 year ago
Very limited quantity of Monster Bash topper figure sets - have been trying to pry these out of Chicago Gaming for months - these are great additions to a desk or other places - has threaded inserts on bottom ...
http://www.planetarypinball.com/mm5/merchant.mvc?Screen=PROD&Product_Code=PPS-MBR-TOPFIGS&Store_Code=PP
#5723 1 year ago
Joining the club! This is a game I wanted to own for a long time. I’ve only ever played a few beat up/routed MB’s, so it’s amazing to play a new one!
#5724 1 year ago
Quoted from PPS:
$169 for 3 figures (!!). Sold Out
#5725 1 year ago
Quoted from bigdog50:
Much cheaper to DIY!
#5726 1 year ago
I got a set. This is how these thing go... end of production run, limited left over NOS parts... get them now or never.
#5727 1 year ago
So excited!
#5728 1 year ago
Quoted from Rdoyle1978:
Much cheaper to DIY![quoted image]
Where are those from? I thought about the leftover topper parts but with another $20 for shipping the cost wasn’t for me.
12
#5729 1 year ago
It finally happened, and everyone’s in love.
7A429EBB-7B08-4D01-A17C-52AD8FB4C7A8 (resized).jpeg9FCCF53F-E2A5-4A37-934B-FF945FBB9AEE (resized).jpeg3F30BDAB-4DD3-493B-AA84-42A8222276E7 (resized).jpegC602436E-E04A-4CC3-9CD1-F533C99942CF (resized).jpegD4095CE2-2E36-4D13-A8AA-848AFEFC823F (resized).jpegF62549AE-08AC-4093-9DF9-72939664162E (resized).jpegFEF51804-374C-49B9-99D0-D94F9363DE15 (resized).jpeg30ABA84E-D590-4F40-BF23-3F794D7534F8 (resized).jpeg
#5730 1 year ago
What a great day ! Thank you for sharing.
#5731 1 year ago
Official Universal Monsters figures from about 20 years ago
#5732 1 year ago
Just joined the club today!
#5733 1 year ago
Now that I've got my ramp issue fixed my game has been playing great. No STDM from the scoop and the feed from the right orbit and creature seems pretty good as well. The only question I have is I went to install the tilt bob today and can't find the locking wingnut anywhere. Was that supposed to be in the bag with the tilt bobber or would it be someplace else?
#5734 1 year ago
My game came with a compression spring for the tilt bob. It was in the same bag.
#5735 1 year ago
Quoted from fusion:
Mine too.
#5736 1 year ago
I received LE 425 last Friday. The game plays wonderfully, well done CGC! I need to fix some minor things like the scoop firing SDTM, but I think I'll just be playing the game for a while instead..
#5737 1 year ago
I’d like to replace the rubbers in the upper right (mummy) pop bumper section w/ orange titans... are those 3/16 or 5/16 rings on all the posts?
#5738 1 year ago
Quoted from tilted81:
Just look in the owner's manual, everything is listed there.
#5739 1 year ago
Quoted from Moeman65:
Mine didn’t come with one, but it’s prolly available online?
Edit: manual just calls them black rubber bumpers don’t see a size...
Edit again: titan has them listed as 3/16
#5740 1 year ago
Edit again: titan has them listed as 3/16Mine came with a real nice spiral type notebook. Much nicer than my stern manuals.
#5741 1 year ago
Mine was a super early one... Ha they were certainly in a rush. They killed it tho. It’s my kid’s favorite game. They all wanna play “ the monster game” haha
#5742 1 year ago
Got notification mine is ready to ship and made the final payment on mine on Friday.
#5743 1 year ago
Ordered my MB LE from Candice at pinballs.com. They have some in stock ready to ship. Ordered 06-25-19 and it will arrive tomorrow 07-03-19.
#5744 1 year ago
Kinda surprised to see so many still around at so many dealers...this is such a good looking machine.
#5745 1 year ago
going to sfge to pick up mb le because of narrow streets on my brothers neighborhood
#5746 1 year ago
Other than the obvious assembly and 6.5 degree playffield setting, is there anything else to do before playing?
#5747 1 year ago
Quoted from gmagno:
Don't forget your balls.
#5748 1 year ago
Quoted from donjagra:
I meant programming, too funny.
#5749 1 year ago
I've had my game for almost 7 months now, got it a bit before Christmas, and it still plays great.
I've had no issues other than the early problem with one corner of a side decal lifting. I pushed it back down and put on a set of plexi protectors on the flipper buttons to keep my hands away from that seam. All is well since.
Glad to see that everyone is getting their machines, even those overseas!
Robert
#5750 1 year ago
Assembling MB at the moment. What are these parts for?
7,999
West Chicago, IL
$ 5,999.00
Nitro Pinball Shop
$ 40.00
The Flipper Room
$ 399.95
Pin Stadium Pinball Mods
