(Topic ID: 265441)
Monster Bash Franky table not going up or down.
By Yesh23
1 year ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Jmckune
#1 1 year ago
I just picked up the game and the table isn't going up or down. All 4 switches work (2 for the target banks and 2 for Franky). I can manual move the gears and they're not froze up and the table and targets have moved up and down but not during gameplay. I have a feeling it's not set to the correct position to start a game. Any help would be appreciated.
AAAA (resized).jpgAAAAA (resized).jpga (resized).jpgaa (resized).jpgaaa (resized).jpg
#2 1 year ago
Will the table move if you activate it in the test menu?
#3 1 year ago
Quoted from Jmckune:
It has but not now. I moved it manually but then it doesn’t
#4 1 year ago
It wasn’t doing anything in the game or test. I moved it manually a few directions and it worked in the test mode but then it seems like it’s out of position
#5 1 year ago
Quoted from Yesh23:
I'd try a separate power source on the motor. See if it works. Rule out a dead field on it. Then go over the mech. Anything binding above or below, anything metal on metal needing a drop of oil ?
#6 1 year ago
Those DC motors will run slowly off a 9V battery. Turn the game off and see if you can get the motor to move to rule out the motor.
#7 1 year ago
Make sure you have 12vdc on the red wire on the motor, and if so run a ground wire to the black wire. Motor should run. If not, bad motor. The switches don't have any effect on motor operation in test mode.
#8 1 year ago
Yeah, either power isn’t getting to the motor, or the motor is shot.
(I would probably go with bad motor as the more likely scenario)
