I picked up a Monster Bash a couple of weeks ago that had been in storage for years and had some issues. I have successfully worked thru all but two of the issues and need some guidance for the Flasher issue.
The problem is when you turn on the machine, it instantly blows F107 fuse for the flashers. I have looked over each flasher to ensure it's not a grounding issue and also removed both the J133 connection & J111 connections - to which the machine still blows the fuse instantly.
So I'm guessing that since I removed both connections and it still blows instantly - it must be a board issue. Is this correct? If so, now how do I diagnose whats wrong with the board. I have no problems with my soldering skills, but the whole multi meter to diagnose is still a skill in progress.
