(Topic ID: 257734)
Monster Bash Display not working
By davidmb
#1 4 years ago
Hello,
I just acquired Monster Bash for a discounted price as the screen is not working. I replaced the screen, but its sill not working . Any idea how I can trouble shoot this ?
Here's a link showing the pinball
Any help would be greatly appreciated
David
#2 4 years ago
Video marked private. Can’t view.
Which version of MB? B/W or Chicago Gaming?
Chris Hibler - CARGPB #31
Http://chrishiblerpinball.com/contact
http://www.PinWiki.com/ - The new place for pinball repair info
#3 4 years ago
Hello,
The video is now public , sorry for this.
I dont know which version , so I took a picture of the model.
Thank you so much for you help !
David
#4 4 years ago
check all the connections.
then need to check voltages.
#5 4 years ago
oh, check fuses too.
#6 4 years ago
You have an original Monster Bash made by Williams. The display looks totally dead, which is caused by a problem on the high voltage section of the driver board. It might be a fuse, but it will probably need to be rebuilt.
#7 4 years ago
You have an original Williams WPC95 game there. Test all the voltages at the DMD power connector. If any of the -110, -100, or 62v is out of spec, ChrisHibler will be happy to repair the A/V board for you.
Also, if the voltages are out, you can go with a ColorDMD and not worry about repairing the board.
https://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Testing_DMD_Controller_Power
#8 4 years ago
Also check the ribbon cable the red stripe goes too #1
2 months later
#9 4 years ago
How do I check the voltage on the DMD connector ?
Also, the pinball emits 7 beeps continuously , the documentation shows: 7 Beeps: S7 sound ROM failure
Now, any idea what it means and how to fix it ?
Thanks !
David
#10 4 years ago
I think you should call your friendly neighborhood pinball repair firm and let them take a look at what you got.
#11 4 years ago
Quoted from davidmb:
Post #7 with a multimeter set for Vdc or V== depending on the labeling on the meter.
#12 4 years ago
Assuming the ROM is oriented correctly, sounds like a bad sound ROM. Post a picture of the (top) A/V board.
#13 4 years ago
Quoted from PinballManiac40:
Here's a picture of the AV Board - Also, I noticed LED100 and LED102 are off on the power board.
#14 4 years ago
You still haven’t told us what the voltage measurements for the display are.
I can see that someone partially replaced the HV section on the board but didn’t replace some of the most failure prone parts.
#15 4 years ago
Could someone explain how and which measurement to take? I have a multi meter , but not sure what to use for the ground
thanks !
David
#16 4 years ago
You have been led to water. Now drink.
As it says in the link ground can be the backbox braid or the side rail.
$ 33.50
$ 29.00
Pinball Photos LLC
$ 69.99
Inscribed Solutions
$ 38.00
Various Novelties
Pinball Photos LLC
$ 5.00
Pinball Fuzz
Pinball Photos LLC
Don's Pinball Swag Barn
Precision Pinball prod.
$ 12.95
$ 399.00
Cabinet Parts
Mödley Crüe
Daddio's 3D Printed Mods
$ 219.00
Lit Frames
Filament Printing
YouBentMyWookie
£ 55.00
Sillyoldelf Mods
$ 24.75
The MOD Couple
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/monster-bash-display-not-working and we tried optimising it for printing. Some page elements may have been deliberately hidden.
