I have an issue with my Monopoly machine where the up/down post doesn't work, neither during the game or in test mode. The machine was like this when i got it so can't be positive how long it's been like this. I swapped the coil with the dice eject coil, both 20V and both run off the same 20V connection on the board @ J7-P1, upon doing this the suspect coil works and the coil eject one doesn't so i know that the coil itself is ok. After swapping the coils back i then checked the brown 20V wire with a DMM on both coils and both read 21.7V so the inoperative coil is getting power and both have continuity on the earth wire to the cabinet ground braid. The ground wire for the up/down post goes to pin 8 on J6 and the Dice eject goes to pin 4 on J6. I have checked over the J6 plug and all seems ok and i even re-flowed the solder to pin 8 just in case it had a dry/cracked solder joint. I have also tested the TIP that relates to that coil and it has the same readings as the one for the dice eject coil so it seems ok also. I'm not sure where to go from here, what else could be the issue? Something on the board i'm missing? I don't think there is a setting to turn the up/down post off in the menu. Any help would be greatly appreciated
