(Topic ID: 78379)
Monopoly Club!! - Own it All!!!
By SilverUnicorn
  • 564 posts
  • 102 Pinsiders participating
  • Latest reply 4 days ago by PinDeLaPin
  • Topic is favorited by 35 Pinsiders
There have been 197 images uploaded to this topic. (View topic image gallery).
There are 564 posts in this topic. You are on page 9 of 12.
#401 4 months ago
Running cpu 3.03 as it says at bootup.
#402 4 months ago
Quoted from PinDeLaPin:
According to the change log, here:
https://mattsbasementarcade.com/product/monopoly-pinball-cpu-display-upgrade-eprom-chips/
3.02 added "always turn in the same direction" but on my machine, running 3.01, I have had several times when the ball got lodged like this and the flipper turned direction and freed itself.
Maybe buy a 3.01 rom?
#403 4 months ago
I figured that would be built into the newer code to be able to free itself but it never reverses itself. Seems a bit silly to have to go back to an older rom to fix this issue. I guess if thats the only way to fix it though then thats what I gotta do.
#404 4 months ago
I used to wax the stainless ball guide and armour all the flipper rubber.
#405 4 months ago
Quoted from fast_in_muskoka:
Now thats good stuff i put carnuba wax on the flipper rubber and the ball guide earlier. Clearly great minds think alike!
#406 4 months ago
Well no go on the carnuba wax a ball got trapped 1st thing this morning. Other than swapping out the rom I think the only other thing to do is to remove the flipper rubber. Im sure it will look like crap but would think that the slick pladtic flipper bat wouldnt pinch the ball.
#407 4 months ago
Maybe i have a weird machine but usually the flipper will reverse direction if a ball gets stuck for too long. I've only had to take the glass off to free a trapped ball perhaps 3 or 4 times. Mine also varies speed sometimes too although it doesn't seem to be specific to any point in the game, perhaps i'm not paying enough attention to it to notice.
#408 4 months ago
Quoted from Mancave:
What version of the ROM are you running? Mine does the same, but I'm running 3.01.
If you're running 3.03, perhaps there's an operator setting burried in the menus?
As for removing the rubber altogether, I would personally be a bit worried about damaging the flipper plastic with direct ball strikes.
#409 4 months ago
Mancave what version of the rom are you running? Mocean you bring up a very good point about embedded operator setting that why im curiius if Mancave is also running 3.03 like me. If he is then my game should also reverse itself unless a setting is keeping it from doing so. My flipper also changes speeds throughout the course of tbe game but only goes 1 direction it never reverses.
#410 4 months ago
Found these templates online for the free parking ramp, the top of the left and right ramp and just to left of the chance trough. Will be getting these cut out and hopefully installed later on today.
#411 4 months ago
Good job with these! I added these to my Monopoly several years ago, and they are perhaps the single best thing you can add to it. Certainly prevents balls from flying off the ramps.
I'm certain I have the link for these somewhere, but if you have it handy, you might wish to post it for others.
Regarding the speed/direction of the mini flipper, I had a similar problem years ago. Perhaps this might help:
https://pinside.com/pinball/forum/topic/monopoly-mini-flipper-spins-like-crazy
I seem to recall also that the single direction (counter-clockwise) of the mini flipper was an update to the code, as has been previously mentioned. I'm running 3.01, and while I have occasional catches of the ball, the flipper will change direction after a few seconds, releasing it.
BTW, the speed of the mini flipper will increase as the water works multiplier increases, thus making the skill shot and subsequent attempts at water works more difficult.
#412 4 months ago
Just checked...and was forced to play some games even if it is 1.40am. Mine is running 3.01. It was originally running 3.03 but i was having up/down post issues as previously mentioned in earlier posts. When i had my main board repaired the up/down post was still not working so a mate kindly swapped me his driver board for the one out of his Simpsons machine and at the same time burned me the 3.01 code which fixed my problem.
#413 4 months ago
Well crap I guess it pretty much sounds like im gonna have to swap out the roms then. Ive never had to do that before and I dont have any friends that can burn me a copy so I guess I will look at that matts basement place. Is the process pretty much simple as removing the old one and setting new one in the old ones place?
#414 4 months ago
Quoted from Scotty_K:
So I thought I would post the link for the plastic protectors in case somebody else was looking for them or just didn't know they even existed. http://pinballzone.com/tech/monopolyflap.php
#415 4 months ago
Yes, it's pretty much straight forward. The ROMs will be labelled with the correct socket locations. If you don't have a chip puller, a small flat screwdriver will suffice. Just pry them up a little at a time from both ends, and try to be careful not to bend the legs. Then just gently push the new ones in, again making sure not to bend the legs. Also, make sure all of the legs are seated properly (I had a bent one once that didn't seat; drove me nuts until I found it!).
If you are planning on acquiring more pins in the future, you might want to invest in a chip burner for yourself. They're not that terribly expensive:
amazon.com link »
#416 4 months ago
I bought a bunch of 1/32" lexan sheets a while back from Amazon. You can cut them with a pair of regular, sturdy scissors. This was how I made the protectors I was missing, and they also work to make plastic protectors in a pinch. Useful stuff to have around.
amazon.com link »
#417 4 months ago
Easiest solution for the stuck ball is to remove the rubber completely. Its pointless on it anyway as it's just aesthetic.
#418 4 months ago
Hey guys this guy is overseas but I contacted him and he offers a full set of decals for Monopoly for $200 shipped his email is pinballdecalseu@gmail.com and all you have to do is shoot him an email and tell him what you are interested in. He has an online store on ebay and is a reputable seller as far as his feedback goes. Seller information: future2015mc9 (279 ) 100% Positive feedback. Just thought I would pass along his information as I have looked high and low for replacement cab decals and found none. Hope this helps!
#419 4 months ago
Definitely interested in cab decals for this machine, gotta be better than the crappy colour matching job the previous owner/s did. I did a seller search and at the moment he only has 3 machine cab decals for sale, when i spotted where from (Croatia) it got me wondering if it's the guy that was printing for Retro Refurbs?
It could be just coincidence but apparently all RR's cab decals were getting printed in Croatia.....interesting
#420 4 months ago
Yeah i'm not sure if he did work for them or not. All I know is he has 279 positive feedbacks for the decals he sells on ebay which leads me to believe they must be good. Cannot believe nobody else is making these as there seems to be a strong demand due to the cabinets always getting beat to hell on these machines. Anyway as I stated above just wanted to pass along the chance to grab some decals as they seem to be nonexistent.
#421 4 months ago
Have you ordered a set for yourself? At the moment i can't spare the cash on a set but definitely keen to find out what the quality is like.
#422 4 months ago
I haven't ordered one of his sets just yet as I am still working on getying my mschine fully shopped out 1st. As soon as I finish the topside i will definitely be ordering a set.
#423 4 months ago
Broke 1 plastic today playing a game. By any chance does a yone have an extra pice they would sell? Its right below the right ramp and the mini flipper.
#424 4 months ago
Thought I would share a mod i put together today after seeing someone else do it. Just couldnt stand to look at those crappy studs on the slingshot plastics anymore.
20180917_131108 (resized).jpg20180917_160521 (resized).jpg20180917_160530 (resized).jpg
#425 4 months ago
How did you attach the tokens?
#426 4 months ago
Yeah i've got a nice 2nd hand spare. It's almost completely flat (very slight bend that would be fine once attached), got a couple of spots on the underneath but they aren't holes in the artwork though, just marks of some kind. I could post it over to you in an envelope sandwiched between 2 bits of thin cardboard fairly cheaply (might take a few weeks to arrive though). What do you reckon it's worth?
#427 4 months ago
Quoted from OTRChief:
First I attached a #8 nut to the bottom of each token basically this nut will be a spacer with a clear 2 part epoxy like jb weld. It only takes 5 to 10 mins to dry so then i attached a #6 nut to the other nut and let that sit overnight so it would fully cure. If it isn't fully cured and you start screwing them on the nuts will seperate from the token. You can get a 10piece set of tokens for 7 or 8 bucks on ebay and the epoxy and nuts I picked up at walmart. You will need 6 of each #6x32 and #8x32 nuts and just 1 package of the 2 part epoxy. If you have a piece of styrofoam you can shove the pieces in the foam upside down after applying the epoxy so the nut doesn't slide off the piece. Hard to describe but you will see why I did that when you start because the epoxy seta up pretty quickly so you have to work fairly quick. Hope this helps it really is simple and really does help in my opinion.
#428 4 months ago
Heres what I used.
20180917_193307 (resized).jpg20180917_193340 (resized).jpgScreenshot_20180917-193722_Samsung Internet (resized).jpg
#429 4 months ago
Not sure if this is happening to anyone else, but on both ramp shots the ball get stucks in the corner. Any suggestions how to fix this? I thought about making a plastic to cover the top of the ramp so the ball doesn't jump off..
#430 4 months ago
Quoted from pacman11:
I posted the fix for this a week or 2 ago.
Menards sells small sheets of the lexan you will need to make these. http://pinballzone.com/tech/monopolyflap.php
#431 4 months ago
...as does Lowes and Home Depot. Just about any home improvement store should have it.
#432 4 months ago
Thanks, that seems easy enough to make..
#433 4 months ago
Thank you for the advice on how to attach the tokens. The use of a #8 nut over a # 6 nut and the Styrofoam comment were very helpful.
#434 4 months ago
Thanks for posting this, reminded me that i still had the templates i printed out floating around somewhere When i did find them and went to cut them out i realised i had printed them at the wrong ratio, think it had "Auto zoom" selected on the print file instead of "Actual size" I did have to trim a little extra off the small one that attaches to the blue plastic (above the green line in pic). There was no way i was going to be able to attach the ramp otherwise, would have been sitting up on that top left edge. When you have a look at the photo of that particular plastic on his site it appears to be a different shape to the template so i'm just not sure if he's altered it but not changed the template. Even when the plastic was rotated around away from the ramp (so the right hand edge of the plastic is touching the pop bumper) there still wasn't enough clearance.
#435 4 months ago
Hey Paul, so after altering it did you end up getting it to fit or no?
#436 4 months ago
[quoted image][quoted image]
Glad my advice helped you out. I love the topper you have on it where did you find the oversized pieces?
#437 4 months ago
Hi Mate, yeah i did but i'm not entirely convinced it will do what i think it's supposed to do
If you bend the tab the other way the angle that the plastic sits at will basically be the same just that the ends will be swapped over, and as you can see from the pic it is rotated as far to the right as possible. I presume it was made to stop balls getting stuck between the pop bumper and the back of the sign and or the ramp itself. As it is it will help to deflect a ball but there is still enough gap for the ball to get between the guard and the lower LED holder on the sign and allow a ball to snuggle next to the ramp (bit hard to see from the pic i know). The guard if anything needs to be more square on to the gap or virtually flush with the edge of the blue plastic to fully prevent a ball getting in behind. To be honest i've never had a ball get stuck there....yet
#438 4 months ago
It's can't believe there was no plastics made for the tops of those ramps. Seems like the game would have been tested by Stern when it came out and they would have noticed that issue right away when the ball flies off the ramp like it does...
#439 3 months ago
I've got some spare clear acrylic left over, might have a crack at designing something that will block that gap a bit more...... watch this space
#440 3 months ago
So I am going to attempt to make these two plastics over the weekend. Do you have a template for this you could attach on here? That way I could just print it out and trace it on a piece of plastic and cut it out.. Thanks!
#441 3 months ago
http://www.pinballzone.com/tech/monopolyflap.php
#442 3 months ago
I looked at that site and somehow I missed the printable ones.. Now I see them they almost don't look big enough when you print them. Thanks!
#443 3 months ago
Quoted from mattosborn:
I used the ramp flap designs from Todd George: http://www.pinballzone.com/tech/monopolyflap.php
I drew them up in AutoCAD and had them laser cut out of PETG. Don't really want to have any more made... but if someone wants my AutoCAD drawing (or exported to some other vector format) just let me know.
I've posted the EPS vector files on my site for download: http://scoresaves.com/pinball/MonopolyProtectors.7z
Good for laser cutting, or just printing out as a template to trace (just make sure your software isn't scaling to fit to your paper source).
#444 3 months ago
I made the topper from Monopoly banks. It was simple to make with a half inch board painted black and 3 banks screwed to the board. I bought the banks either from Amazon or EBay for about $20 each. They may cost more now because I don't think they are still being produced
#445 3 months ago
I installed on of the lexan sheets to protect the free parking. It became allot harder to get a ball up that ramp and hit the free parking. Has anyone had this? I have considered somehow raising the right side of the plastic a little bit bc the ball bumps the cover right as it goes from first part the ramp onto the straight part that leads to free parking.
#446 3 months ago
Quoted from topkat:
I did have a few issues with that too when i first installed the guard but then i screwed it down with the ramp screw. In the template there was no hole for that area so i'm not sure if the guard was supposed to sit on top of the screw originally. When screwed down it lifts the right hand edge up, seems to have helped a lot.
#447 3 months ago
Made my plastics last night. Now I just need to instal them thanks for the cut outs.
#448 3 months ago
My next project are the cliffy. Been lazy with those since it’s allot
More diss assembly
My plastic might be too long after seeing her phoot
#449 3 months ago
But it’s that ramp junction, clear in your photo, where the ball hits the top and loses speed to the free Park
#450 3 months ago
So here's my prototype solution for that small lower guard. It will block a ball going in behind the sign completely and if a ball goes onto the pop bumper it will just roll straight back onto the playfield. I might make it taller so a ball can't fly up and drop into the gap between the top LED bracket of the sign and the prototype guard. Although there isn't enough space for a ball to drop into that gap there is a slight possibility of a ball sitting there. There is a gap on the ramp side of the upper LED bracket but upon testing a ball will roll straight back onto the playfield below the chance scoop (mind you it would be a serious air ball to jump into that gap). Thoughts? Suggestions?
3,200 (Firm)
Royal Oak, MI
Metal-Mods
Trade
Machine - For Trade
New York, NY
$ 40.00
$ 1,000.00
Playfields
Pinball Playfields
Lighting - Backbox
PinSound
$ 9.99
$ 38.75
The MOD Couple
$ 7.00
APB Enterprises
$ 76.95
