Quoted from Mancave:So here's my prototype solution for that small lower guard. It will block a ball going in behind the sign completely and if a ball goes onto the pop bumper it will just roll straight back onto the playfield. I might make it taller so a ball can't fly up and drop into the gap between the top LED bracket of the sign and the prototype guard. Although there isn't enough space for a ball to drop into that gap there is a slight possibility of a ball sitting there. There is a gap on the ramp side of the upper LED bracket but upon testing a ball will roll straight back onto the playfield below the chance scoop (mind you it would be a serious air ball to jump into that gap). Thoughts? Suggestions?
Your prototype fix looks pretty good to me Psul have you been able to put some games under your belt and put it to the test yet?
