Hello all...
I've just recently finished swapping the playfield on my Monopoly. One thing that was causing me issues before I started was the bank door, and figured if I saw a decent replacement emitter/receiver I'd pick it up. I luckily found one and replaced.
The original problem was the 2nd switch (the "A") was not registering. After replacing, the same issue continues. While the playfield is up, and observing the testing lights on the bank opto board, when I block "K" it's fine..."N" is fine...."A" doesn't do anything...and "B" closes both "B" and "A".
Is this a connector problem? How would I test this?
Any suggestions would be appreciated,
Thanks for your time,
Mike
