(Topic ID: 19065)
Modified Harbor Freight Lift Table
By wizzardz
11 years ago
  • 1,219 posts
  • 373 Pinsiders participating
  • Latest reply 6 days ago by Ballderdash
  • Topic is favorited by 413 Pinsiders
    9 key posts have been marked in this topic (Show topic index)
    There are 1,219 posts in this topic. You are on page 17 of 25.
    #801 4 years ago
    Quoted from VirtualMayhem:
    Thanks calfdemon for responding to the bleed question. Spiderpin - are you placing the table under the pin from the front or the back - I believe with back legs going up last your lifting from the front side of the pin. I think I will skip the bleeding part of this
    Yes I slide in from the front. Front being the coin door and start button, that's the side the handle of cart is at. So when I load to to my truck the backbox go in first.
    20181109_124152_HDR (resized).jpg20181109_124152_HDR (resized).jpg20190311_162216_HDR (resized).jpg20190311_162216_HDR (resized).jpg20190311_162052_HDR (resized).jpg20190311_162052_HDR (resized).jpg
    #802 4 years ago
    Thanks for
    Quoted from Spiderpin:
    Yes I slide in from the front. Front being the coin door and start button, that's the side the handle of cart is at. So when I load to to my truck the backbox go in first.[quoted image][quoted image][quoted image]
    Wow the pics are helpful, I figured you dropped the handle down to pull it without hitting front of machine but wasn't sure. I'm as prepared as I can be for tomorrow One of the pins I am moving is Sopranos..
    #803 3 years ago
    I have the 500 lb Hf Lift, and I noticed that when I go to lower the lift, it goes down SUPER SLOW. any tips on how to get it to come down a little more smoothly ??
    #804 3 years ago
    Quoted from Trindawg:
    I have noticed if you squeeze the release twice it comes down much faster on the second squeeze.
    #805 3 years ago
    The release valve is super touchy on these. Tighten the cable carefully - too much and it will come down on it's own.
    #806 3 years ago
    I'm jealous, mine takes a very very fine touch to get a slow descent. Anything past that and it rockets down.
    #807 3 years ago
    Add another bimini mod to the books!
    I drilled the tubes and replaced the set screws with bolts so no worries about them loosening up.
    Thanks all for figuring this mod out and documenting it.
    1588632494666409594046047738674 (resized).jpg1588632494666409594046047738674 (resized).jpg20200504_184146 (resized).jpg20200504_184146 (resized).jpg
    1 month later
    #808 3 years ago
    So one of my casters just failed (the tread or rubber fell off the frame) on my lift I bought 3 years ago from northern tool. I've probably used it on 4 to 500 moves.
    Since they don't sell replacement sets I went looking for substitutes. Also I'm fine spending a descent amount on a new set of casters if they last, even a bigger plus if the weight capacity increased because of it. Pinball is primarily what I use this lift for, but it helps with other items as well.
    Was thinking about decreasing the size of the back tires by 1 inch and keeping the front at 5 inches. Mainly because when you start lifting the back is substantially higher then the front. on old games with crappy bottoms, I try to be super careful. When one end of the lift hits it puts a lot of strain on that part of the cab, till it evens out.
    The angle would be 1.7 degrees across the 32 inch platform, but I'm having a hard time thinking of any negatives without putting it in to practice. The slope would be negligible for the most part, but I figured anything that helps.
    back wheels (I need to check the plate to make sure they match first)
    https://www.buycasters.com/Albion-4X2-Medium-Duty-Swivel-Caster-Grey-p/bc42s16xs02.htm?CartID=1
    front wheels (fixed)
    https://www.buycasters.com/5-x-2-Solid-Cast-Polyurethane-Wheel-p/bc-d-hugr5x2-pbb.htm?CartID=2
    #809 3 years ago
    Where is the best price for the bamini ends? Thanks
    #810 3 years ago
    Quoted from crlush:
    Go to the first page of this thread and follow the Bimini Mod key post link. All info shall be revealed...
    #811 3 years ago
    Quoted from crlush:
    https://pinside.com/pinball/forum/topic/modified-harbor-freight-lift-table/page/12#post-4889884
    Check out key post #594 where I detail it all. Bikini caps can be found for under 30 bucks for the pair
    #812 3 years ago
    Anybody know if Harbor Freight does Ship-to-Store? They don't have the lift table at my local store (next closest one is 60 miles) and if I'm paying $100 for shipping, I might as well just buy it at Home Depot and take it home today
    #813 3 years ago
    Anybody got any tips on replacement wheels? Mine disintegrated into a hundred pieces while sitting in my garage.
    #814 3 years ago
    Quoted from Rdoyle1978:
    Call your local store and ask.
    Since the virus shut downs etc, things may be different than in the past.
    #815 3 years ago
    Quoted from toastbot:
    Amazon
    #817 3 years ago
    Has anyone had problems lifting from the bottom panel. I would think you would be too much weight and pressure?
    #818 3 years ago
    Quoted from Gorgar666:
    If the cabinet is new or good shape, shouldn't be a problem. That is where pinball carts pick them up from.
    #819 3 years ago
    So, turns out, the most common use my lift gets is raising the legs off the floor to level a game. I used to just lift the front of the game by doing a pushup. Now, raise the game, adjust, drop it, check the level, repeat if necessary.
    #820 3 years ago
    Quoted from ThatOneDude:
    It's also a handy little portable table.
    I use it when working on all sorts of things not pinball related. Really nice to have a flat surface for tools that is perpendicular to any part of the bench.
    #821 3 years ago
    No. In hundreds of games this has only been an issue maybe 2/3 times for me, on old games with the cabinet falling apart.
    It seems to distribute the weight evenly enough that it is generally not a problem.
    #822 3 years ago
    Quoted from CrazyLevi:
    I have used my hflt to setup and take down machines at shows. Literally hundreds of times. If a machine can't handle being raised by its bottom panel you will probably be able to tell just by looking at it. In these rare cases simply flip the table around and use the bottom edge of the sides to raise the game instead of the bottom panel.
    #823 3 years ago
    Good info guys thanks.
    #824 3 years ago
    I had a game that look like it was ready to collapse. I cut two old 2x4's about an inch wider than the width of the pin. I placed them on the lift 3" before making contact.
    #825 3 years ago
    So I went through this whole thread, and all the options are interesting. I tried 3d printing a 45 degree connector to link the stock handle, but the littlest force would snap it in half. I tried to see if PVC would work. 3/4 PVC outside diameter is VERY close, but a bit too tight (1.05"), and then you still have to figure out a coupler between the PVC pipe and the metal tube.
    So after taking some measurements of everything, I discovered that the inside diameter of the chrome tube is very close to the outside diameter of the bottom lift handle socket, like within .1mm. Now that might not sound like a lot, but even after grinding down the powder coating with a wire wheel it was still too thick...
    So out comes the angle grinder. If you're careful and grind in straight lines, you can maintain the round shape fairly well. Few tips
    1. absolutely wear goggles
    2. try to wedge a piece of wood to prop the tube away from the bottom to give you maximum space (so you don't end up grinding the cart base or the cable)
    3. Keep checking fit, make sure you're staying consistent up the tube
    After it seems to fit good, you can use the wire wheel to smooth things out. You may want to also spray the surface with oil so it doesn't end up rusting (if you grind enough you may be able to repaint it)
    Once you fit it over, line up the hole of the tube with the hole in the lift socket. Time to get the drill out so you can make a hole through the pipe so you can put that bolt through.
    After chopping through the middle of the handle with a tubing cutter ($6 at harbor freight), I 3d printed a plastic handle so I don't cut my hand on the sharp edge. You can obviously find stock handles that fit over a 25mm pipe, but I'm cheap (and have a printer)20200623_174701 (resized).jpg20200623_174701 (resized).jpg20200623_174705 (resized).jpg20200623_174705 (resized).jpg20200623_185420 (resized).jpg20200623_185420 (resized).jpg20200623_185431 (resized).jpg20200623_185431 (resized).jpg
    #826 3 years ago
    Quoted from cconway84:
    I spent $269 on the table and another $7 to modify it. See pictures for detail.
    The 1000lb table has a larger more stable lifting surface than the 500lb lift and has a folding handle to store it under a pin. It fits between front legs easily. However the handle won’t fold backward so the lift can slide further under a pin from the front.
    There is a metal bar at the hinge on the side by the lift. I’m shown holding it in its original place to demonstrate. Cut this bar on either side where it meets the metal tabs with a reciprocating saw and a metal blade. Cut the bar at the other hinge also. The handle will now swing backward.
    Use a 5/16” metal drill bit to drill through the tabs on each side where the bar was welded in. Pass a 1/4” x 2” round head wire lock pin ($3.52 x 2 of them) through the holes. This locks the hinge in place to use upright again. Remove the pins to lower the handle backward.
    This modification cost $7 and took me all of 15 minutes. Four cuts and four drilled holes. It preserves the original strength and design to use the lift handle upright while letting the handle fold back to move the table under games and to fold forward as designed for storage.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
    Thank you for showing this mod. Super easy and cheap to boot...
    #827 3 years ago
    Decided to do another mod.. obviously since the cart is only 18" wide you need some sort of board to extend the platform (but it needs to be narrow in order to fit under the pinball and slide past the legs).
    So I decided to build pivoting arms. To start off you need a pair of snap ring pliers (HF also has these cheap)
    https://www.harborfreight.com/snap-ring-pliers-with-interchangeable-heads-63845.html
    So that you can remove the two pins towards the side away from the handle. Then you need to drill four 1/4" holes. Each board will be 13" long and still be able to pivot without hitting each other:
    Mark a round at the end. Use a protractor, or find a bottle that's close. I simply used my chopsaw and made a bunch of cuts (doesn't need to be perfectly round, just close). chop saws are preferred over a jigsaw so your cuts are straight.
    Mark your hole, 1.75" from the sides. Use a 3/4" spade bit to recess down just below 1/2 inch.. Either use a drill press, or use a drill and a pair of calipers:
    Once your recess is good, you need to drill a hole in the center of that. I'm drilling at 1/2" because I bought some 1/2" O.D. nylon spacers from homedepot.. They had a couple that were 1" long but not enough so I had to buy the pairs of 1/2" long:
    Your bushing needs to spin freely on the outside. You are clamping down on the center with a 2" bolt and a washer/nut. Since I didn't have anything larger than a 1/2" bit I had to wiggle it around a little to elongate it slightly.
    Now you can slide it under your pin, then pivot the arms out:
    #828 3 years ago
    Nice idea
    #829 3 years ago
    I did look through the thread but, well.... I looked rather quickly. Apologies if this method has already been posted. I used hinged boat rail couplings in my cart mod. Very much looking forward to finding out that I've contributed something!
    Added over 4 years ago:
    https://smile.amazon.com/dp/B07VVXX3T6
    #830 3 years ago
    What size diameter are they? Nice job!
    #831 3 years ago
    Quoted from Jrotten:
    They are 1 inch (25mm).
    I should also mention that.... just minutes ago... I tried to move a pin that my cart just barely would not fit under so I'm thinking it might have been better to make the cut at 20" above floor height rather than the 21" that I went with. Having to cut it down another inch shouldn't have any negative effect. We shall see.
    #832 3 years ago
    Quoted from Bad-Sir-Ivan:
    You did!
    Thanks for the vid.
    Got aa link to those Joints anyhywhere?
    #833 3 years ago
    Quoted from guitarded:
    Here ya go! Also put one in the video post.
    #834 3 years ago
    Added yesterday: amazon.com link »
    Oh HELL YEAH. That's what I'm talking about. Nicely done.
    #835 3 years ago
    I like the bimini end mod the best but my cheap ass wouldn't spend the $30 so I welded some 3/16 pieces of angle iron to the pipes after cutting them around 6 inches from the bottom and used 2 5/16 bolts.
    20200719_164000 (resized).jpg20200719_164000 (resized).jpg20200719_164022 (resized).jpg20200719_164022 (resized).jpg20200719_183207 (resized).jpg20200719_183207 (resized).jpg20200719_183213 (resized).jpg20200719_183213 (resized).jpg
    #836 3 years ago
    OK, after years of faithful service, my cart blew a tire!
    The black plastic that they call a tire cracked off of the hub. I can't find parts for this on HF's site. Do you know of any good replacements? Worse comes to worse, it'll limp along when needed.
    Edit: While the part is not listed in their replacement parts catalog, they do offer a bunch of casters. I guess it's time to head off to the store.
    3 weeks later
    #837 3 years ago
    Thanks @Bad-Sir-Ivan, this was the nicest solution, I just did mine within 10 minutes after waiting a few weeks for my package arrive.
    https://www.aliexpress.com/item/32919265179.html get the 25mm, two of them including shipping is about $25 total. You will need a 3mm hex key to tighten them.
    I used the $5 Harbor Freight pipe cutter at 16 inch from the floor to make the cuts, probably 17 inch from the ground also would have worked, but not higher to fit under my lowest machine.
    #838 3 years ago
    Here is what I did to eliminate lifting from the machine bottom panel..I remove them when in storage and roll the cart on top, under the machine..
    cart1 (resized).jpgcart1 (resized).jpgcart2 (resized).jpgcart2 (resized).jpg
    3 weeks later
    #839 3 years ago
    Anyone have ideas for a substitute for this part ? Looking to do a bimini mod but part out at Amazon
    Screenshot_20200912-140117_Amazon Shopping (resized).jpgScreenshot_20200912-140117_Amazon Shopping (resized).jpg
    #840 3 years ago
    Hey TheMickster - What are those red urethane wheels on yours? Aftermarket? Source? Better than the stock grey ones that don't have bearings, I assume?
    #841 3 years ago
    Quoted from Gogojohnnyquack:
    Hey themickster - What are those red urethane wheels on yours? Aftermarket? Source? Better than the stock grey ones that don't have bearings, I assume?
    I bought the cart probably 15 years ago and I don't think I changed them out, must be how it came back then....
    #842 3 years ago
    I don’t think they are better. That cart really isn’t designed to move pinball machines around, and with too much use those red covers fray and fall off, and the black wheels left behind are soft and mark up the floor. I shouldn’t complain I got 6-7 years out of mine before the wheel covers started to fall off but I don’t think it’s anything you need or want. And yes they came stock on that cart.
    #843 3 years ago
    Curious, has anyone's lift failed to keep it's height? I've had mine for years and currently have a project cab sitting on it. Noticed today it lowered itself completely. Lifted it back up, few hours later, lowered again. Piston going? Or is there something else I should look at?
    #844 3 years ago
    It's leaking.
    #845 3 years ago
    Release handle cable adjusted too tight?
    #846 3 years ago
    Quoted from LTG:
    It's leaking.
    I was thinking that, but no obvious wetness.
    (I'd attach a pic but it keeps failing to attach "Upload error! Unknown error."
    #847 3 years ago
    Quoted from Irishbastard:
    Might work on gas or air.
    #848 3 years ago
    Quoted from LTG:
    It's a hydraulic lift, so I assume hydraulic fluid, no?
    #849 3 years ago
    You'd think so.
    #850 3 years ago
    Reading up on hydraulics. Could be several things. Some that break down over time, or even evaporate.
    This page was printed from https://pinside.com/pinball/forum/topic/modified-harbor-freight-lift-table/page/17 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
